CHT monitoring
I've been looking for digital readout cylinder head temperature monitoring systems and found this beauty.
JP INSTRUMENTS EDM-700-6C - Gulf Coast Avionics Bummer it's way over my budget. Anybody know of a less costly solution without all the datalogging and cost adding FAA certification? This type of readout would look great in a 930S console while being quite useful insurance for engine health monitoring ... no? ![]() ![]()
http://www.youtube.com/user/pdqcarrera |
Wer bremst verliert
I have one from Westach...it is an analog gauge with a 6-position switch to select which cylinder you want to monitor. I found #5 runs hottest so I just leave it there...you kind of see the gauge in this pic...
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Spruce aircraft has a 4 channel one for much less.
MGL AVIONICS TC-1 EGT/CHT MONITORING SYSTEM from Aircraft Spruce You can divi up / reconfig the channel(s) for different stuff like EGT. |
Omega.com has all sorts of thermocouple options and meters. You can find all sorts of app notes and info.
Thermocouples i-Series 1/32, 1/16, 1/8 DIN Programmable Temperature/Process Meters with RS232 & RS485 Communications Standard
Norm '86 930 AEM Infinity 6 - Twin Plug 3.6L - DBW - JE Pistons/LN Eng. Cylinders - Pauter rods - GT3 Crank - GTX3584RS - ID1050x Injectors - Ported Intakes - Custom Intake Manifold, exhaust and intercooler - 993SS cams - ECUMASTER PMU-16DL HRE Wheels 560R 8.5x18 ET25 (Front) 11x18 ET0 (Rear) |
