replacement radio
Hello all, I'm in need of some information. Just removed my C-1 alpine radio, went over to best buy to get a replacement of some sort and was told that I was SOL. No cable to interface w existing wiring, would need a new preamp and speakers. Needless to say, that didn't sit too well. Does anyone out there know of a radio that I can just plug in and/or where to get a interface cable. And if that can't be done, does anyone have any suggestions?
Hi Rick, Go to the link I have listed below for the best service on a new radio. If you have not cut your wires you can most likely match them up. Crutchfield normally asks for the yr., make, and model car you have and they match up the wire connections. If I did not place the wiring diagram color code used in the FSM on here I will do so. You can go back to Best (WORSE) Buy and tell them off.
www.crutchfield.com/ Cheers, Larry |
Larry, thanks a bunch. Called Crutchfield and got everything I need. Now I'm just waiting for the radio to get here.
I ordered this:
http://www.crutchfield.com/p_120701822/Receiver-Wire-Harness.html?showAll=N&search=merkur+wiring+harness&tp=2977&avf=N Which matched up to my '87 930 wiring harness. Eric |
