Co%
To fellow 930 enthusiasts,
I have a stock 89 930 USA version. My car underwent an emission test and the CO measured 1.25% at idling(950rpm). Our emission regulations here in the Philippines allows until 4.5% for cars made in 1989. My question is whats the normal CO% ( specs given by the factory) range for my 930. Is 1.25% to lean ? Thanks in advance, TDH888 |
Get rid of your O2 sensor and set the CO somewhere between 2.5 and 3.0. That's about where I run mine and I think quite a few others do the same. Listen to how she sounds and runs for optimum. You have a lot of room for adjustment in the Phillipines.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
My car loves 3%.
1998 993 C2S Guards Red/Black 1990 964 C2 RWB project car 2016 GT3RS White Daily driver 2018 Lamborghini Performante Gegio Telesto |
Wo ist die Rennstrecke?
Is your WUR stock?
PM sent!
3% at idle is where you want to be. Check when on boost to make sure you aren't leaning out. That's where it's important. IF your CI 'SYSTEM' is working correctly then it 'SHOULD' adjust for you automatically as the RPM rise.
Bill 997.2 |
Mark, Is it imperative to disconnect the O2 sensor so that the car can be used w/ 2.5-3% CO or can i adjust my CO from 1.25 to 2.5-3% w/ the O2 sensor in place and not encounter any drivability problem? TDH888 TDH888 |
Set to 3% with the sensor disconnected. When re-connected, it will lean the mixture out for emissions reasons, but primarily at idle conditions only.
