Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Elombard's Avatar
Silly newb ? 87 930
I am helping my neighbor with his 87. I pulled the IC and plenum off and fixed some vac leaks that were hopefully causing no idle.
replaced all the orange rings and a few hoses.
Buttoned back up and spins over but no start.
removed the green plug on the CIS flapper - fuel pumps both seem to be running, starts for a second then quits and will not re-fire.
I have the air box off....that wont affect starting will it? I was thinking some of the lines and hoses that connect to the air box might be a big air leak or something??
I need to check for spark I guess and hook up the gauges and check the fuel pressure...
Any other thoughts...its been sitting for 3 or 4 weeks just need to get the CIS primed?
Erik L.
erik.lombard@gmail.com
84 lime green back date (LWB 911R with RS rear flares) hot rod - absolute riot to drive!
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 10-10-2009, 06:47 AM
beancounter
jwasbury's Avatar
Can't hurt to throw the CIS gauges on just to check pressures at this point. Its easy since the airbox is already removed.
The symptoms still sound like a massive airleak somewhere...
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 10-10-2009, 07:06 AM
Did you put the intercooler back on?
Old 10-10-2009, 07:24 AM
Elombard's Avatar
Yes I put the intercooler back on, however not confident with the seal from the cast pipe at the cold side of the turbo (runs up to the IC). It never seemed to snap in. It snapped in on the intercooler end but not the turbo end. Thought If I could get it running I could check for a boost leak there.
Erik L.
Old 10-10-2009, 07:31 AM
Turbo Hooligan
Try starting it while someone holds the CIS plunger down just a hair. if it starts and runs with someone holding down the plate slightly, then you have a massive air leak as Jacob said. we've been there done that at carolina motorsports park.
www.d-zug.com
blog.d-zug.com
All these guys do is drive too fast, work on cars, chase ******* and drink.. really no fun at all...
Old 10-10-2009, 12:27 PM
Elombard's Avatar
Ok will do in a second.
Just checked for spark and its flashing the timing light.
What are the 4 hoses that connect to the air box?
1.) to WUR
2.) Large breather return from oil tank
3.) medium attaches up near CIS plunger???
4.) medium attaches near large breather.
Those Ok vented to atmosphere or do I need to put the box back on? Cant imagine it would matter..
Erik L.
Old 10-10-2009, 01:06 PM
Turbo Hooligan
they're fine vented to atmosphere. I wouldn't worry about the airbox until you have everything sorted
www.d-zug.com
blog.d-zug.com
Old 10-10-2009, 01:48 PM
Elombard's Avatar
OK I Got It! Using your advice I got it running opening the flapper, then I found my leak.
Actually this was probably the problem all along.
The cast pipe that comes up from the cool side into the IC was just flopping around.
There must be a piece missing because it is not long enough to fit down on the Turbo snugly.
I am going to check the PET and see if I can see it.
Anybody got a picture of what these parts look like? Its got to be some kind of gasket/grommet in addition to the orange ring.
Erik L.
Old 10-10-2009, 01:59 PM
Elombard's Avatar
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?command=show_parts_image&Headers_Id=37181&Line_Item_Number=20
This part is not there, and was not there when I took it apart..no wonder.
Erik L.
Old 10-10-2009, 02:05 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
You don't have to have that piece in there. I took mine out years ago.
Make sure the turbo is clocked right, the up pipe is in the right orientation )spin it around just a little to seat it properly) and the intercooler is down all the way.
Originally Posted by Elombard View Post
Old 10-11-2009, 02:18 PM
Elombard's Avatar
WOW...
OK running to the garage.
Is the correct order of assembly then to put the up pipe on the turbo and then the IC on? I put it on the IC first.
It does not seem like the up pipe fits well on the turbo. I am going to post some pictures.
Erik L.
Old 10-11-2009, 02:42 PM
Elombard's Avatar
WOW...
Erik L.
A930Rocket's Avatar
Up pipe first and then set the intercooler on.
Old 10-11-2009, 02:45 PM
A930Rocket is correct, #20 is often MIA. Don't need it.
Scott - 1987 930: 3.45L Supertec engine w/GT3 crank, California Motor Sports upgraded 930 trans, modified suspension, Zuffenhaus 9's and 11's, black on black..."The Black (Financial) Hole"
Old 10-11-2009, 03:16 PM
Elombard's Avatar
Here is some pics of the up pipe and the end of the turbo.
This Turbo is brand new...did the shop put the wrong one on???
Or is this all you need to get a good seal, it does not really "pop" on?
ugghhh...the orange doughnut goes on the turbo first and THEN push the up pipe down on top.. doesnt it....
Erik L.
Old 10-11-2009, 03:59 PM
Turbo Hooligan
yes, the orange O ring should fit in a groove around the turbo.
www.d-zug.com
blog.d-zug.com
Old 10-11-2009, 04:37 PM
Turbo Hooligan
I may be wrong though...I haven't fooled with any KKK turbos in 9 years now.
www.d-zug.com
blog.d-zug.com
Old 10-11-2009, 04:40 PM
Banned
That is not where/how the orange O'ring is supposed to be fitted - the O'ring is supposed to go in a groove on the exit of the compressor spout (on the turbo) - the the "up pipe" snuggly fits OVER the O'ring. . . if that turbo is not a 3LDZ (the OEM turbo) but is a K27 varient, then you will need to buy the aluminum adaptor that enables you to fit the up pipe to the turbo (the K27s to not have the groove for the O'ring) . . .
I believe that RarelyL8 (a member on this board that posts often) sells the adaptors and probably has a pic of one you could look at . . .
Installing the adaptor and O'ring can be very frustrating as the fit is VERY snug - you will need plenty of lube, patience and some spare O'rings (as there is a good chance you will rip a few until you get the feel for it) . . .
Old 10-11-2009, 05:00 PM
Banned
You also need to use two O'rings with the adaptor - one goes on the inside groove of it and one on the outside groove . . .
Old 10-11-2009, 05:02 PM
A930Rocket's Avatar
Everybody has it right. Looks like the turbo has been swapped out. This could e why it's short? Don't they all have a "lip" at the top of them? Makes the adapter a b*tch to get off once it's on there.
Old 10-11-2009, 05:16 PM
