Which clutch for 400+ rwhp on 3.3 turbo 965
After engine modifying/rebuild i fitted a genuine equipment "sachs" clutch kit including pressure plate whilst in there...Now a few thousand miles on and just above 1 bar boost around peak torque i experiance clutch slippage back and forth!
In hindsight i maybe should have went for an uprated clutch during rebuild however as the new sachs clutch i fitted also is the same part fitted in the 4wd 993 turbo, i thought it would handle the power although obviously its running very close to the wind in what it can handle..
I know maybe in the near future i will be needing to replace and i was wondering what my best options would be for 400+ rwhp??
SP Autobahn www.spautobahn.co.uk
Porsche inspector for Peter Morgan UK
http://www.porscheinspections.com/
"92" 964 turbo,Modified and recently rebuilt using all ARP hardware..
Purpose built fuel controller set up to acheive perfect fuel curve on CIS inj.
Old 10-12-2009, 01:16 PM
mark houghton's Avatar
I'm suprised it can't handle the 400rwhp. I wonder if maybe you have a small leak from the oil seal at the flywheel, getting on the disc? Just a thought since the new clutch shouldn't give you any trouble.
Other options on clutches are several. My personal favorite is the pressure plate build by Kennedy Engineered Products. They have three different stage levels available. I run with a Stage 1 Kennedy and a Sachs disc, and about 370hp at the flywheel with no issues.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 10-12-2009, 01:45 PM
Crotchety Old Bastard
RarlyL8's Avatar
Sachs Sport Clutch will support 400whp. I agree something is not right.
Old 10-12-2009, 02:17 PM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
A G50 PP will support 460 ft lbs with a 930 srung hub organic disc. But there is a 8mm and a 9mm disc. They both look the same except the 1mm....... Could be a 8mm disc with a 9mm PP possibly?
87 911 Carrera platform
Twin Garrett's, Big Valve, Xtreme Cylinder Heads, JB Racing cylinders and machine work, custom JE pistons, GT2 EVO cams, GT3 oil pump, modified 3.2L intake, 80mm TB, custom Intercooler, equal length headers, DFI, KEP Stage 2 custom twin disc, G50 custom gear set, LSD, Tilton trans pump, Fluidyne cooler
Old 10-12-2009, 04:49 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
I used the Sachs clutch after my rebulld and it started slipping soon after. Adjusted the clutch and it would work for a very short period. Went to a KEP Stage 2 and it's been good since.
Old 10-12-2009, 05:05 PM
Turbo Hooligan
Kennedy stage 4 or whatever their highest street disc is...supports my abusing.
www.d-zug.com
blog.d-zug.com
All these guys do is drive too fast, work on cars, chase ******* and drink.. really no fun at all...
Old 10-12-2009, 05:22 PM
David's Avatar
Another vote for Kennedy.
2014 Cayman S
2011 Cayenne Turbo
Old 10-13-2009, 05:00 AM
RarlyL8's Avatar
What is the max torque/HP that Sachs will hold? There is a huge difference between 400WHP and 500whp.
Old 10-13-2009, 05:05 AM
If I were having a problem with a clutch holding HP, I beleive I would get in touch with Bello either direct or through Juan here on our host site as Eddie has been through all of the problems with holding a large amount of HP.
Old 10-13-2009, 06:21 AM
Cynical Misanthrope
AFM744's Avatar
Send a message via Yahoo to AFM744
Problem with the KEP solution is, as I understand it, there is no application for the G50 format. The 965 uses the same clutch format as the 964, as well as the 993 and 993tt, BUT with the CIS three-tooth reluctor ring. Now in my rummaging at Parts Heaven I discovered that you can knock the pressed-on reluctor ring off your 965 DMFW and put it on any G50 DMFW. So any G50 format clutch might just work. One popular 965 solution is Patrick Motorsports' LWFW, which I believe follows the Carrera RS LWFW format, which requires a different pressure plate and drive plate. That kit was prohibitively expensive for me.
X-1, AFM744, Jon, '92 C2 Turbo
JE 8:1 pistons, 964 cams, 38mm intakes ported/polished/twinplugged, ARP hardware, B&B headers/exhaust, 355whp. Full-blown GT35R 3.2 intake EFI pending...
Where my misspent time and money is currently going.
Old 10-13-2009, 08:19 AM
My boost started to vary up over 1.05-1.1 bar on my gauge at around 4k revs and then the clutch would slip!
Car has over 400rwhp at just less than 1 bar so maybe 1.1 bar may be nearer 415+rwhp and then i have slippage on a sachs 964 turbo clutch after only maybe 3-4k miles
99% sure no issues with any fluid etc going on to my clutch plate causing slippage!
Another subject but this boost pressure varying i tracked it down to being a worn valve guide on my aftermarket wastegate...pressure which should have been lifting open the valve with pressure on the diaphram was leaking down past the valve stem..
I noticed this by applying very little air pressure to the wastegate and before the valve was lifting i could hear leakage through my 965 wastegate tailpipe(or dump pipe in the 930 application).
Made new st/st valve guide on my lathe(old one was mild steel and had over 0.012" thou clearance)....
New st/st one i made was reamed out to only have 0.004" thou clearance..Fitted and boost as steady as a rock now so no slippage however i reckon the clutch may be needing replaced sometime in future or i require more clamping force!
Turning new st/st valve guide
Reaming I/D of guide so closer tolerance to valve
New stainless steel guide next to old mild steel worn one which was causing boost varying issues
Old 10-13-2009, 09:56 AM
A930Rocket's Avatar
You have your own lathe? I would settle for a drill press!
Good work!
Old 10-13-2009, 06:31 PM
Yeah got my own lathe in my garage still,being a "toolmaker" to trade at one stage i had numerous machines but sold the majority of them since i dont manufacture stuff as much and tend to do more Porsche work now...If i need to manufacture any components etc i just pop over to my old company i used to work for and use their equipment now
Old 10-14-2009, 12:56 PM
Send a message via AIM to turboguy934 Send a message via Yahoo to turboguy934 Send a message via Skype™ to turboguy934
i have a spec stage 3+ clutch and never had any problems
Old 10-18-2009, 08:57 AM
Metal Guru
911nut's Avatar
FVD has some options for heavier pressure plates: FVD Brombacher Online Shop
Patrick Motorsports has some too:Patrick Motorsports - Clutch Covers - 3.3L six cylinder (1991-1993) 965 Parts
Kennedy Engineered Products now sells the equivalent of a Stage 2 pressure plate for the 965, good to 650 ft-lb, lighter than the Sachs pp and rebuildable.
Porsche recommends replacing the dual mass flywheel (DMFW), not resurfacing it. When that is factored in the cost between the DMFW and a lightweight flywheel package aren't much different.
I'd love to try a lightweight flywheel but there is so much in the way of conflicting opinions among people that have tried it that I'm unsure of which way to go.
Paul B.
'91 964 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, - 210 lb
Old 10-24-2009, 08:51 AM
