Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
jopo911's Avatar
AC Belt Removal
Does anyone know how much horsepower might be gained by removing AC belt? '86 930. I never use AC, and know it is probably taking some horsepower . Also, any damage to compressor leaving it sit idle with no belt?
Joe
1986 Black on black 930
Kokeln IC/ 1 bar spring/European Fuel Head
GHL Exhaust Dual Exhaust, Wevo shifter and coupler
935 Front Air Dam, Forgeline wheels
Old 10-12-2009, 02:31 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Not sure how much HP it takes to spin the AC, but when it's not engaged, it's free wheeling. Regardless, I used to remove my AC belt at the track, then just cut it off one day when I didn't have time. Never re-installed it.
To keep the system working properly, it would probably be best to use once a week for a short period, even in the winter to keep all the seals, etc. in good shape.
Old 10-12-2009, 04:28 PM
pete3799's Avatar
HP gain 0
When the A/C is off your just turning the pulley.
Pete
79 911SC RoW
Old 10-12-2009, 04:47 PM
mark houghton's Avatar
If you don't intend to use it, then take the entire darn boat anchor outa there. Save some pounds, gain miniscule mpg and performance. Or, just enjoy easier access to the engine.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 10-12-2009, 04:56 PM
