juan ruiz's Avatar
5 TH Gear QS
I'm looking for the specs of the gear ratio for the G50 gear box stock to see what mph can be reached from the stock box, then I'd like to know what gear ratio I should have to for 5 th gear for top speeds and lastly how much they are, can I buy them used ? Who has them ?
Old 10-17-2009, 06:10 PM
Infidel
JBL930's Avatar
Can't help on what your top speed will be, but this info might be of use?
Codes and years
G50.00 1987-1989** 3.2 Carrera, Rest of World version
G50.01 1987-1989** 3.2 Carrera, US/CDN/Aus/Jpn version
G50.02 1987-1989** 3.2 Carrera, Swiss version
G50.03 964 C2 1990-1992 1L is plain, 2L is M220
G50.04 964 C2 1990-1994 Swiss version
G50.05 964 C2 1992-1994 US/CDN version including RS America
G50.10 964 RS (street legal basic race car, non-US)
G50.20 993 C2 US/CDN/Swiss version
G50.21 993 C2 ROW
G50.31 993 C2 RS version ROW only
G50.32 993 C2 RS M003 (clubsport) version ROW only
G50.33 993 C2 RS Swiss version only
G50.50 3.3 Turbo 1989 first G50 turbo version (larger ring & pinion)
G50.52 965 C2 Turbo 1991-1994
Ratios
G50/00 3.5 2.059 1.409 1.074 0.861 (after 1988 0.868) diff 9:31
G50/01 3.5 2.059 1.409 1.125 0.889 (after 1988 0.892)
G50/02 3.154 1.895 1.333 1.036 0.861 (after 1988 0.868)
G50/03 3.5 2.059 1.407 1.086 0.868
G50/04 3.154 1.895 1.333 1.029 0.868
G50/05 3.5 2.059 1.407 1.086 0.868 diff 3.333:1
G50/10 3.154 1.895 1.407 1.086 0.868
G50/50 3.154 1.789 1.269 0.967 0.756
G50/52 3.154 1.789 1.269 0.967 0.756
Jonathan.
87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines.....
Old 540 BMW, XB12S Modified, for being a total hooligan
Old 10-18-2009, 02:08 AM
lite75's Avatar
Look for a 5th gear set from a 50 or 52 turbo box, great for top end.
75 930, 76 930, 83 SC EFI turbo
Old 10-19-2009, 11:38 AM
juan ruiz's Avatar
thank you guys, any idea where I can find one of those ?
Old 10-19-2009, 05:21 PM
You might want to start with a goal MPH.
For reference, what was the top speed of the RUF Yellow-bird assuming it was pulling around 550hp and was also a narrow body thought it had some drag improvements.
Then get with someone that has a gear ratio calculator and come up with what gear ratio you need.
Do you know what your MPH would be with your existing gears at your red line?
Old 10-20-2009, 05:20 PM
juan ruiz's Avatar
Great Suggestions
I be happy reaching 190 mph, I have to look to see what MPH yellow-bird top end was, and then I need to find the someone to help me with the calculations
I know I have run 142MPH on the 1/4 mile at the end of 4 th gear at 7800rpm if thats of any help
Old 10-20-2009, 06:57 PM
I have a gear chart for a late 915 that Bill V. did for me. It looks like on my car 7500rpm is good for about 170mph.
Old 10-20-2009, 07:24 PM
