Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
e p slick's Avatar
Blowing off intercooler hoses on 7000 RPM shift question
Ran the Texas Mile last weekend. Blew off intercooler hose on 7000 RPM shifts - 4of 6 laps. Sometimes in hose, sometimes out hose. Only way to get down the course was to short shift at 4000 RPM.
My guess is diverter valve but I do not have enough knowledge to be convinced. Apprecuiate any and all input/suggestions.
EPS - Arizona
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 10-20-2009, 10:30 AM
MikeD930's Avatar
Do you have any beads on the intercooler and pipes? What type of hose clamps are you using? Don't know if this problem would be related to a diverter valve.
MikeD
'87 930
Old 10-20-2009, 12:26 PM
copbait73's Avatar
Show some pictures and give boost pressure.
Old 10-20-2009, 01:56 PM
If your diverter valve dose not vent properly, you will see a very high pressure spike between the compressor and throttle plate beteen shifts.
You would also run the risk of damaging the turbo. You can even shear the turbo shaft in some cases.
Do you still have the throttle bypass valve installed? This should bypass some pressure around the throttle plate.
Old 10-20-2009, 02:05 PM
e p slick's Avatar
.8 Tial - calibrated and accurate. Some oil residue in IC tubes.
Old 10-20-2009, 04:28 PM
mark houghton's Avatar
Really stupid question: Have your IC mounts loosened up, or your muffler and/or turbo mount? May just be flexing/moving so much that it pulls the pipes/hoses off. Especially an issue with the aluminum in pipe and O rings. Move any more than a half an inch and you lose the seal.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 10-20-2009, 06:52 PM
Macht Schnell
les_garten's Avatar
I've had mine do that if i didn't clamp the crap out of them.
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 10-20-2009, 09:25 PM
Manassas, VA
lucittm's Avatar
7000 RPM shifts?
4000 RPM short shifts?
Just for discussion sake, how much power/RPM do you have AFTER a 7000 RPM shift?
Redline?
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 10-21-2009, 06:15 AM
Again, the purpose of the deverter and the throtle bypass to a lesser degree is to vent pressure between shifts and on throttle lift.
With the aftermarket bypass's you typically hear a faint "woosh" sound with the valve working correctly. No woosh, no workie!
Also, if with a quick shift you do not come instantly back to full boost the valve is not working. If it is not back to full boost instanly and it takes a sececond to build boost back up from say .5 bar between shifts it is not working properly.
If you are running a C2 turbo black plastic Bosch bypass, they often fail.
On my car I had no loss of boost with sport style shifts once my system was dialed in.
Old 10-21-2009, 06:37 AM
e p slick's Avatar
Thanks everyone for the input.
EPS
Old 10-21-2009, 01:06 PM
