torresmd's Avatar
Suspension installation advice
OK I have decided to lower my car myself. I enjoy working on my car although my mechanical knowledge and experience is very little. I bought several books including the Bently service manual. I think I finally understand how to reset the rear torsion bars. I have also decided to upgrade the suspension while I am at it. Here is what I have bought:
Hollow Torsion Bars 23 front 28 rear
Sport shocks front and rear
Tarret sway bars front and rear
Elephant rubber bushing kit for control arms
Neatrix rear spring plate bushing kit
So I have a few questions:
1. Is their anything else I should consider replacing or upgrading while I am at it. I only want to get an alignment and corner balance once. Also forgot to mention that this is going to be primarily a street car with occassional track use.
2. When I start the job, should the car be level on all four jack stands or can I do the front first then the rear next. Seems like from my reading, the car should be level.
3. Does anyone have a diagram or recommend the jack stand points since my usual spots are where I will be working.
Thanks guys!
1986 930 Slant nose Black/black RUF
2004 996TT Gaurds red/Black EVO GT 660
2001 Ferrari 360 Spyder Rosso/Tan
1969 Carrera Widebody TurboKraft Custom (Mexico Blue)
2001 E39 M5 Imola/Black-red interior
Old 10-24-2009, 11:46 AM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
To make ride height and corner weighting easier, I would think about adjustable spring plates as well.
I would do one end at a time although there's probably no reason you couldn't do it all at once. Helps to keep parts and thoughts organized.
A level suface works best and that's for all four wheels. You may need to shim up one or more tire pads to get accurate readings. You'll also need to settle the suspension and roll the car off and on you pads.
For jack points, I would use the torsion tube in the rear and in the front... I can't remember. Maybe the the jack points just behind the front wheels.
Old 10-24-2009, 12:28 PM
Non User
infraredcalvin's Avatar
+1000 on the adj spring plates
I just helped a friend do a similar suspension refresh, would have made fine tuning a snap. He says he wished he got them every time we bring up his car...
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
'75 914 GT clone project
'74 914 track basket-case
Old 10-24-2009, 02:36 PM
torresmd's Avatar
Thanks guys, I will consider doing adjustable spring plates. Any brand inparticular?
Old 10-24-2009, 06:49 PM
torresmd's Avatar
Old 10-24-2009, 07:05 PM
A930Rocket's Avatar
I only know of the Sway-A-Away sold here. Not sure if the Elephant Racing gizmo does the same, but it's a lot more money.
Old 10-24-2009, 09:10 PM
What is your goal or use with the upgrade.
Double check your torsion bar combination it seems like unorthodox.
It is perishingly stiff front and very much on the soft side for a 930 rear upgrade.
Something like 22/30 might make more sense for a 930.
21/28 would just be a little stiffer. 23/31 or 23/33 would be full race.
Old 10-24-2009, 10:11 PM
Smart quod bastardus
fredmeister's Avatar
Yes the 28 rear bar is lite for a 930....
Elephant racing has a nicer sway away adjustable spring plate than the typical weltmeister unit. It is more safe in that the adjustment nut cannot slip or bend as with the welty unit.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 10-24-2009, 11:22 PM
torresmd's Avatar
Thanks for the advice. I realize now that I have the wrong combo of torsion bars. I think I will have to send the ones I have back and get 22/30's. What a bummer! Delays my start date but I guess it is better to make the change now rather than later.
Old 10-25-2009, 01:11 AM
