trevs911's Avatar
Average miles P G for 88 930
Have a 88 930 Turbo 54, miles getting about 12 miles to the Gal.Normal driving, shift
around 4,rpm.run in the 4s 3rd gear 70-80 mph. is that good or bad MPG?
Old 10-26-2009, 12:25 PM
Registered Abuser
MT930's Avatar
Seems normal on the road I average 11.0MPG with IA fuel head.
The track norm for me is 6-8 MPG.
MT 930
1987 930 - Gone but not forgotten
A man with priorities so far out of whack doesn't deserve such a fine automobile.
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
американский
Old 10-26-2009, 12:53 PM
Crotchety Old Bastard
RarlyL8's Avatar
12-15mpg on the highway is not abnormal if you have a stock WUR. With tuning an adjustable WUR will bump highway driving to 21-24mpg and city driving to 13-15mpg depending on mods.
Old 10-26-2009, 12:59 PM
Thats about what I get with all around driving too.
On the highway at steady speeds around 70mph near sea level you should be able to get around 20-22 mpg if it isn't running too rich.
They weren't made for fuel economy, but aren't bad on the highway.
Old 10-26-2009, 01:01 PM
icemann427's Avatar
If you are traveling 80+/- mph on the freeway, I don't see any reason not to be in fourth gear. I have made a number of 450 mile freeway runs in fourth gear without any lugging at about 85 mph and was getting 23 mpg.
Old 10-26-2009, 02:01 PM
Turbo Hooligan
i get around 8-10 cruising and around 3-6 gettin it. but I have a LOT of mods on CIS. she just drinks from a big gulp.
www.d-zug.com
blog.d-zug.com
All these guys do is drive too fast, work on cars, chase ******* and drink.. really no fun at all...
Old 10-26-2009, 02:18 PM
I have gotten as high as 27-28 at between 75-90 mph on certain parts of my drive from Monterey CA to Milwaukee with a stock 1979 930. I was surprised as I was not really trying to get good MPG.
Anthony @ Voitureltd Bayside WI.
Old 10-26-2009, 02:31 PM
trevs911's Avatar
Thanks guys!I don't Feel that bad with the Mpg I'm getting Then.
I should be driving with the high RPMS 4 to 5s right?
Also on the cool down,if I'm driving slow 15 -20mph does that do the same as idle for a few
min. before turning off ?
Old 10-26-2009, 03:27 PM
mark houghton's Avatar
I get about 20 mph on cruise. Probably would be a little better if my rear tires weren't all worn out. Could get even better if I were to run at stoichiometric 14.7 AFR, but she doesn't like to run quite that lean (closer to 14 + a couple tenths).
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 10-26-2009, 03:54 PM
Tinkering Pays!!
mooney265's Avatar
Why wouldn't you shift into 4th at highway speeds??? I'm a little confused.
BTW: I have such low gearing and small diameter tires, that at 3,500 rpm, I'm going 70 MPH in 4th gear!!
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 10-26-2009, 05:19 PM
HoyaBear
hoyabear's Avatar
Send a message via Skype™ to hoyabear
My old 88 was dead stock and that used to get about 16-18 on the highway. My 86 gets about the same as the 88 did, but it has significantly more mods and runs pig rich (still need to tune this thing), go figure?
'86 930: 3.4 Andial build, Web GT2 Evo cams, Carrillo rods, ported/polished heads, MSD 6530, B&B headers/exh + intercooler, K27HF, 1 bar spring, Tial wastegate, Andial FE, Lindsey Fuchs. Back in black!!!
Past:997S cab; '88 930; '86 951; C5 Vette; 4th Gen Z28; 3rd Gen Trans Am GTA; '71 Z28
Old 10-26-2009, 09:56 PM
Large Member
krasuskyp's Avatar
Reading all this was a good confirmation. When I pump fuel I just x10 every gallon going in and put in and know the range I'll get. I usually factor in the likely street/hwy mix, figuring 10 street 16-18hwy (depending on traffic / mood). Track worse.
turboPALOOZA 2300mi trip saw some surprisingly 'better' mileage than I'd expected, considering shenanigans / debauchery
So 12's an all-round good #.
Oh this is on my exhaust/intake'd stocker '87 with 165lb Jenny Craig and a more than a few screwz loose (missing?) behindst der wheel.
Paul... CT | '87 930 | '08 M3 6gang vert |
past:
| '07 S6 | '98 M3 vert | '01 M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 S8 | '95 S6 6gang | '88 M5 | '87 190E 2.3-16 |
Old 10-27-2009, 04:56 AM
Smart quod bastardus
fredmeister's Avatar
12-14 city.
20-21 highway only.
Track driving 7-8mpg.
Completely stock WUR in my 79 930 with mods seen in my signature.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 10-27-2009, 08:23 AM
On average I get I'd say 19 mpg in my 1992 turbo. That includes highway miles and some around town.
Of course I have a 5 speed, so I don't what kind of a difference that makes. Probably not as much as the elevation. Most of my driving is around 5,000 above sea level. I have some mods as well.
Bill
Old 10-27-2009, 09:38 AM
nreed's Avatar
Avg 12-15 MPG. AFR around 12-13.5
Norm '86 930
DTA P8Pro ECU - Synapse BOV - 60# Siemens inj - K27HF - Dual GHL - Kokeln IC - Elgin SC330 cams -
HRE 560R 8.5x18 ET25 11x18 ET0
https://flic.kr/p/nVgoAC
Old 10-27-2009, 02:02 PM
86, stock, except no smog and fabspeed muffer, 87K miles, 20mpg on hwy cruising 70-80.
Tim
1986 930
Gone:71,2,4 914's, 70T, 71T(RS),77S
Old 10-27-2009, 04:22 PM
Wo ist die Rennstrecke?
DonE's Avatar
I have an EFI car, but thought I would post: 26 - 28 mpg highway, 17 - 18 mpg city, 12 - 13 mpg WOT track/de. 3.4L, 4 sp, 525 rwhp.
Old 10-27-2009, 04:29 PM
Send a message via Skype™ to djdawson2
Quite a range of responses. I've taken my 89 on several lengthy trips. I typically cruise at 85+ and have never been below 20mpg... more typically 23.
Old 10-27-2009, 04:36 PM
xbmwguy's Avatar
when i went to the last palooza i avgd 22 up 95 @ 75-80 (until some mustang or vette had to be shown who the REAL king of the road was) he he he
Old 10-28-2009, 04:50 AM
