-   -   MSD Retard...anyone using it??? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/509305-msd-retard-anyone-using.html)
patkeefe 11-06-2009 01:31 PM
I'm thinking about picking up an MSD retard system for the SC. Anyone using this? I'm curious as to your impressions of how it has performed for you.
TIA
Pat
mark houghton 11-06-2009 04:15 PM
Yes....but why would you want an ignition retard for a normally aspirated SC engine? It won't retard a single degree without a boost signal.
patkeefe 11-06-2009 04:31 PM
I have a boost signal generator installed on the SC...Borg Warner T04B H-3 trim. :)The former configuration with the old Rajay may have had detonation issues. I want to be able to retard the ignition.
http://forums.pelicanparts.com/uploa...1257553754.jpg
911st 11-06-2009 04:35 PM
Patrick,
Just wondering, dose the turbo blow through the metering plate or suck through it?
How are you getting enrichment on boost? Do you have a Turbo WUR on it of some type?
Thx
mark houghton 11-06-2009 04:45 PM
Boost signal generator....I like that! I've got one too!!
There are a few of us using this method to gain some ignition advance pre-boost. They work just fine and can retard as much as 15 degrees off your timing. Some experimentation is needed to tune when, how much and at what rate you want to retard, but they're really quite straighforward. If you're already using an MSD6AL for your spark, then simply purchase the boost timing master 8762 and hook 'er up!
patkeefe 11-06-2009 05:04 PM
The SC system passes throught the top section of the airbox, and goes up through the metering plate, which is opposite the 930, I believe. I am attaching a photo of the SS airbox and the tubes. It works pretty well, but it was not engineered to do this, so I have done a lot of tweaking the past few years. I have BL WUR and RPM Boost Controller. I have two fuel heads I have used; IA is way overrich, and the stock late SC is a bit lean on top. Of course, I have a stock SC distributor, which is why I want to use an MSD retard unit.
Mark, that is almost exact to the word what the MSD tech told me today...just put an 8762 on it!
http://forums.pelicanparts.com/uploa...1257555742.jpg
http://forums.pelicanparts.com/uploa...1257555768.jpg
iamchappy 11-06-2009 05:56 PM
Pat i was using a MSD BTM on my Sc engine with 9lbs of boost. i had it set at (I think) hard to remember just under 1.
patkeefe 11-06-2009 06:01 PM
Hey Chappy!
I'm going to be at 5.8 PSI on the new setup for now. I was running 26 degrees total advance on the SC distributor, the car ran like crap on less.
The only thing left of my BAE is the boots now.
Got that tub of yours running OK?
Pat
iamchappy 11-06-2009 06:44 PM
Actually just got the bugs sorted out of it tonight, i was having an intermittent ignition loss, after tons of checking wires i finally found the one with a back connector.
So i am officially all systems go, BLAST off......
"The only thing left of my BAE is the boots now."
I remember when that is all i had left on, now all i have left is the instruction manual.
John at J&S 11-06-2009 06:48 PM
How about boost retard with individual cylinder knock retard and a bunch of other stuff?
MSD tech's have been kind enough to send a few sales our way when the customer asks them for a knock controller.
iamchappy 11-06-2009 06:52 PM
Well aware of your system John, hope to have one someday....
patkeefe 11-06-2009 07:14 PM
John:
I sent you an email a few months ago. I'll resend it again from work on Monday (it's in that computer).
Pat
JFairman 11-06-2009 08:42 PM
Just put a MSD 6AL and 8762 on my car. Driven it only a couple times, I put the knob in the car in between the seats.
Opened the plug gap to .040"
You can feel the power change and hear a difference in the exhaust as you turn the knob while accelerating.
I havn't played with the threshold adjustment on the box yet. It's set at 3psi. I want to try it at 5psi
With 7:1 compression I don't think you need to start retarding timing until 5psi in the cooler air.
I like it
911st 11-07-2009 07:28 AM
J,
Cool!
The MSD effect should be most in the lower RPM's where it is most difficult to fire with the low effective compression ratio. More total power should come from more ideal timing advance.
It is great to hear your car responds significantly to more advance on boost. I have always suspected there is some solid gains to be had with a 930 on the ignition side that most are not accessing.
Seems like if the non-retarded timing settings are near there ideal you would not need a boost threshold hurdle before the MSD starts retarding. EFI guys that pull up to and more than 40 deg advance on cruse pull back timing very quickly when intake vac starts to go away. Delaying the boost level where retard starts should only be necessary if the off boost timing is not at its peak or ideal level.
I guess you could turn up the boost retard on the MSD to add protection. Then start increasing the advance at the dist until pre boost is at its best. Then start pulling back retard at the MSD to dial in the on boost power.
As total advance is sensitive to ones AFR's, it is interesting to me that one of the weaknesses of CIS where is goes a little fat in the middle of the RPM range might actually balance out a motors natural tendency to be more sensitive to total advance it the same area of the RPM curve.
Your findings would be nice to have on the CIS timing thread for those that follow.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/500986-ultimate-930-distributor-advance-retard-timing-turbo-lag-msd-mod-thread.html
The best!
patkeefe 11-07-2009 08:06 AM
In my case, I have 8.4:1 static CR, so I am not as boost dependant. I still run stock SC distributor, basically a stock SC ignition system. I believe all engines love advance, just that our combustion chambers are not optimum for flame front propagation, hence the twin plug variant. So, for the little hemis we have, advance = piston death. I believe John's system takes the guesswork out of how much advance can be safely run.
mark houghton 11-07-2009 09:01 AM
Originally Posted by 911st (Post 4997099)
J,
Cool!
The best!
As I've been known to say, there are benefits to the MSD advance/retard scenario. I've had no complaints over the 2+ years that I've been using it. Still working on finding the optimum settings, and since my adjustment knob is not in the cockpit as is Jim's, it's not quite as handy to just dial-and-go on the fly. I believe there are 3 or 4 of us now using this technology...collectively we'll come up with the optimum.
patkeefe 11-07-2009 09:25 AM
Well, I just decided to go with the J&S Safeguard. I believe it takes the guessing out of detonation threshold. I suppose I can advance at my stock SC settings, and let the Safeguard reign in the advance when I get to unsafe condition. One problem I have found is that I can't hear detonation from my engine...it's a loud car, and especially at the track, with a helmet and that engine screaming, I can't hear a thing. May as well implement some modern technology to supplement my stone-age CIS.
I will let you all know how it works out, if I ever get my car back together.
911st 11-07-2009 03:35 PM
Mark,
You certainly have.
There are three different benefits I think I see here.
Two possably from the MSD effect.
First it has the hot multiple sparks that help ensure the lean AFR's that come with CIS under low effective compression pre boost can be ignited.
Secondly, it allows for a hotter spark on boost where the high effective compression ratio makes the mix hard to fire. (This can be had from hotter CDI non stock system other than MSD.)
The third is from a more ideal timing curve (also available from a non MSD system.)
All good stuff.
How much is from the MSD who knows. I suspect much of it is achieved from a more ideal timing curve as the stock Porsche system is a pretty hot system to begin with.
I suspect if we could find a non-MSD programmable system that uses MAP and intake air temp inputs, we could make a significant amount of improvement to.
911st 11-07-2009 03:48 PM
Pat,
What type of system dose the SC dist use? Is it a vac-advance-pot?
If so, how much advance comes from the vac advance and what is the total advance run?
The early euro 930's used a vac-advance system. At idle there was no Advance as it was a ported connection. Of idle at low load the vac-advance would pull timing up to -26 or -29 depending on setting. Then with acceleration vac advance would go away and pull back timing back about 10 deg.
Not an expert nore even know much about the aftermarket knock sensor systems, nore do I want to get into a debate/discussion on it. However, I would not trust it as my main way to achieve boost retard. I would think of it more as a modest level of back up should the basic setting be off.
I believe that when Porsche added knock sensing to there system, one of the changes they found necessary was to change the style of chain tensioners and create a hard mount bridge or something across the cylinders for the sensor to deal with the noise/static that comes with an air cooled motor. Much easer to install on a water cooled motor with a solid block/cylinder config. Otherwise false reads might cost one timing un-necessarily.
JFairman 11-07-2009 04:04 PM
Cost of doing the whole MSD conversion was a factor for me.
I bought the MSD 6AL box used in new condition here on Pelican for $150, and the MSD 8762 boost retard box which was new and never installed off ebay for $139.
The MSD epoxy encased blaster high vibration coil was about $50 new so the whole thing was about $350.
Both the 8762 and the 6AL came with long magnetic trigger cables with black shrink tube on them.
You only need one of those cables to hook up to the green coax distributor wire so I used the other to lengthen the identical cable for the adjustment knob to reach inside the car between the seats.
It works really well.
I roll up the windows and close the sunroof when listening to the engine for detonation. I know the sound.
If you don't make it detonate continuously while intoxicated in the red mist... I don't believe the rings will break or melt the edge of the piston crown next to the exhaust valve.
mark houghton 11-07-2009 04:22 PM
Agreed. I wonder if any such thing exists.
Not that I'm stuck on MSD (just happend to already have the 6AL in my car when I bought it, and only another $120 bought me the boost timing master), but here is MSD's most recent that gives even more programming options
MSD 6530 Digital Programmable 6AL-2 Ignition:eBay Motors (item 220506987834 end time Dec-07-09 04:30:55 PST) A good price, too!
patkeefe 11-07-2009 04:55 PM
I don't have the breakdown numbers regarding the contribution of the vacuum and centrifugal advance components to total advance. I was running around 26 total, but that is with no load. I am going to be a little more diligent in the future and try to obtain the advance data a bit better, and I will surely check it when it goes back on the dyno.
I agree with JFairman regarding the cost issue, but as I mulled this over coffee this morning, I decided that after two rebuilds, I ain't taking an more chances. Maybe if I had a regular 930, which is a more or less known quantity, maybe, but since I have basically a one of a kind deal, I will go J&S. I have no doubt the MSD will perform quite well, I was just looking for some feedback when I started this thread.
I don't think my piston failure was due to detonation, although some have told me it was. I don't want to do this rebuild thing again anytime soon.
As an aside, the 968 and the 986 in the garage, which reflect approimate generational jumps in Porsche engineering over CIS, are amazing with the sensors and the functionality of the CPU's to perform engine management. Static CR is way high, they never knock, and are good on gas if I don't beat the crap out of them. Not at all like the little turbo SC.
mark houghton 11-07-2009 05:57 PM
I'm intrigued with the possibility of the J&S, though their web site didn't give out as much info as I would have liked as to how to hook it up with CIS and standard non-ECU ignition applications (maybe I need to look closer). It would be nice to run as much advance as needed and not worry about individual cylinders detonating as a result of timing and/or fueling issues. If you go there, do please keep us posted!
John at J&S 11-07-2009 08:56 PM
http://forums.pelicanparts.com/uploa...1257656104.jpg
mark houghton 11-08-2009 08:24 AM
Originally Posted by John at J&S (Post 4998326)
Thanks John! Much better.
Now for the stupid questions:
Is there a particular model number of the Safeguard Porsche 930 applications that a person should use for ordering purposes?
I presume this will hook right up to my MSD6AL, since I'm not using the stock Porsche CDI unit any longer.
Regarding the knock sensor, does it (or do they) come with the kit? Isn't a sensor needed for each cylinder?
911st 11-08-2009 08:26 AM
And, where and how do you mount the Knock Sensor?
JFairman 11-08-2009 08:52 AM
I remember pics of a circuit board, is there a weather sealed case for it?
How long has it been in production, how many are in use on street cars, and how is reliability?
Seems you would have to have 6 sensitive discrete knock sensors and with a noisy air cooled motor with no water jacket to dampen and partially isolate mechanical noises what are the chances of timing errors?
If the electrical components are today's generic chinese computer grade I would be skeptical in the long run.
If they are hand selected/tested military or hospital grade or something similar and in a weather sealed case than I would have more confidence that it wouldn't go haywire or into a default mode and blow a motor.
..and of course, how much $
John at J&S 11-08-2009 09:41 AM
The "universal" version was redesigned last year, and I included two features especially for Porsche.
One is an "ac" output to simulate a mag pickup signal. MSD triggers on the rising edge of the mag pickup signal, but Bosch CDI triggers on the falling edge. I included an output polarity select mode switch so the unit could trigger either type.
The other is provision for a second coil driver, for use with dual distributor. One box can drive two coils, without need for MSD. The second driver can be added for $20 on request.
The unit is designed for Bosch or other "donut" type knock sensors, available from many sources for around $50. We can supply them with your order, including shielded cable with connector and pins.
These sensors have an 8 mm mounting hole in the center. I've seen posts about the factory knock spiders, so why not use them if they are available. Sensor mounting torque is 15lbs.
Note that only one sensor is required is do individual cylinder control. Mounting a sensor on each cylinder won't help to identify the knocking cylinder, as they will ALL hear it.
The knocking cylinder is the one that just fired. Software "knows" that cylinder won't fire for two more revolutions. When it's ready to fire again, software dials in the calculated amount of retard for THAT cylinder.
Sealed units are not available. Some of the components are rated for 70° C, so the unit must be mounted in the passenger compartment. Standard harness length is ten feet, but I can make them to any length you want for an additional charge.
I've been producing individual cylinder knock controllers since 1991. Thousands in use. Very low failure rate.
JFairman 11-08-2009 10:16 AM
I want to say thanks for the product development and availability and your description of it.
Are any of them in edurance racing or drag racing competition use?
Also wondering does anyone use such a device for piston aircraft or are the twin ignitions used in aircraft tuned conservatively and don't need it?
Seems altitude and temperature changes while flying would require active ignition control.
John at J&S 11-08-2009 11:01 AM
Racers are very secretive. If any are using my product, they keep it to themselves.
I've trolled the web looking for high profile users, or just guys going fast, but haven't found much. I did turn up this link:
http://www.enginecombination.com/viewtopic.php?t=153
Link to new aircraft ignition using combustion pressure sensors for knock control:
General Aviation Modifications, Inc.
Note they use the term "safeguarding the engine from detonation".
mark houghton 11-08-2009 12:03 PM
I just read six pages of discussion on this topic, sceptics and believers alike. The general consensus is that knock sensing on air cooled 930 turbo engines does work. The caveat is that it may sense false positives and retard timing when not necessary, leaving HP on the table.
Anyway, good reading, form your own opinions.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/405586-knock-sensor.html
patkeefe 11-08-2009 04:32 PM
Here is some John De Armond stuff from 1992:
http://yarchive.net/car/knock_sensors.html
Edit:
BTW, John De Armond is like Early_S_Man. He is a pretty sharp electronics guy. He has a couple of websites which may or may not be of interest.
John at J&S 11-08-2009 04:56 PM
Pat:
I've run across that link several times, and at one time tried to get in touch with him. I was trying to contact him to run a test on it.
From what I was able to gather, he's an engineer that retired from the TVA, where he was involved in nuclear instrumentation. He seems to know a lot about many subjects.
John at J&S 11-09-2009 08:17 AM
Here's another one from JDA:
Ignition (John De Armond; Dave Williams; Jon Lusky)
Lots of great information about ignition theory.
I didn't run across these links until I got on line in '99. I have to admit I was a little hacked off to see he was talking about one upping me in '92, but I guess it never came to anything.
patkeefe 11-09-2009 09:07 AM
John, this is a guy that built a Pyrex cylinder head to observe spark. Hands on testing is just so cool. Read some of his powerplant stories if you have time to kill, they are pretty funny. One of my buddies used to build nuke plants (I have stories the general public should not know!).
What is the knock frequency range, around 6 kHz? I suppose it is chamber volume dependant?
John at J&S 11-09-2009 01:21 PM
Bosch wide band knock sensors respond to all knock frequencies.
patkeefe 11-28-2009 06:22 AM
Well, I got my J&S in the mail testerday. I also picked up a used MSD retard unit on Ebay for calibration purposes). John pre-wired the harness for the dual knock sensors. I have determined that I cannot use a factory bridge unit for the knock sensors, as my old SC heads have no provision for mounting the bridges.
I am considering simply putting in a long 6mm bolt on the shroud on both sides of the engine, and bushing the knock sensors from 8mm to 6mm to fit. At least this way the sensors will actually be mounted directly to the cylinder head, and I can get a bit of symmetry from bank to bank.
forwheeler 11-28-2009 02:03 PM
Please keep us informed on this install. I am very interested in knowing if you get any false positives.
patkeefe 11-28-2009 03:28 PM
Knock Sensors Installed
Well, I did manage to get the sensors installed today. I ended up drilling out the 6mm holes which hold the shroud on #3 and 4, and tapped them to 8 mm. I put in 45mm studs, with two washers on the bottom. The sensors are pretty secure, and should get a good signal there. I suppose it's not ideal, but we'll see how it works out.
Since I had the shroud on and off a few times, I put the 14mm plug rings I was using for cylinder head temperature sending right on the fins of the head on #1 and 3. JB Weld with a spring paper clip. The bits of wood shim are there til the JB Weld dries.
http://forums.pelicanparts.com/uploa...1259450759.jpg
http://forums.pelicanparts.com/uploa...1259450774.jpg
http://forums.pelicanparts.com/uploa...1259450791.jpg
http://forums.pelicanparts.com/uploa...1259450803.jpg
911st 11-28-2009 06:41 PM
Just a thought, if you have a choice I am wondering if it might be better to be opposite the cam chain end of the motor. You are mostly going to be sampling two cylinders and it might be best to try to be a isolated from the cam chains as possible. I has been said that Porsche redesigned the chain tensioner on the 3.6 to reduce noise that might interfere with knock sensing.
A second thought might be to sample the center two cylinders hoping any detonation in the adjoining cylinders might be transfered through the cam towers. I do not know if the center cylinders might run hotter and be more issue prone. I think the one near the oil cooler might be the hot spot but not sure.
I am thinking such a set up without the bridge may or may not neccessarly be helpful if one cylinder is going lean like if one injector is clogged. More so if the motor is running over the edge.
Not an expert, just thinking out loud.
Hope it all works out no mater.
