-   -   Wideband AFR sensor location (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/510730-wideband-afr-sensor-location.html)
mark houghton 11-15-2009 01:02 PM
Originally Posted by john930 (Post 5011753)
I attached my sensor at the end of the muffler and it is connected to a XD-16 gauge on the dash. This works well and was straightforward to connect.
http://forums.pelicanparts.com/uploa...1258266555.jpg
http://forums.pelicanparts.com/uploa...1258266597.jpg
John, I at one time considered doing the same with a direct-to-muffler mount, but my only concern was being able to keep the sensor vertical between 10:00 and 2:00...to keep the condensation from settling on and ruining it. So I opted with installing in (on top of) the tail pipe and snugged up against the muffler.
Fears about ambient air back-wash (10" for every 3" of pipe diameter...come on, who in a 930 has 30" of tailpipe available!?) are really only a concern at idle when not enough exhaust velocity exists. But we don't install AFR monitors to see what's happening at idle, so who really cares? With that said, mine reads just fine at idle regardless of being only about 10" from the outlet (maybe the fact that the pipe has about a 30 degree bend helps in this regard).
Speedy Squirrel 11-15-2009 01:14 PM
I think the location depends on whether you are using the sensor for control, or to just monitor AFR. For control the optimum location is as close to the cylinders as possible. This means mounting it before the turbo. The problem with this is that exhaust pressure throws off the reading, which is why it is usually suggested to mount it after.
For EFI with the capability for it, you can correct the AFR reading for the pressure effect using this formula:
AFR(corrected) = (AFR(measured) + B x P) / (1 + C x P)
where: AFR(corrected) = the AFR corrected for exhaust pressure.
AFR(measured) = the AFR output by the AFM.
B = 0.009140 for AFR < 14.57 (rich).
B = 0.012100 for AFR >= 14.57 (lean).
C = 0.000627 for AFR < 14.57 (rich).
C = 0.000830 for AFR >= 14.57 (lean).
P = the exhaust pressure in mmHg above the pressure at which the sensor
was calibrated (using the CAL POT on the AFM while the sensor is held in air).
Valid for -152 mmHg < P < 532 mmHg.
964 T #304 11-15-2009 02:31 PM
Mark ,I have over 30" of tail pipe on my 964 turbo and if you measure through that muffler to end you p;robably do also. I tune my afr @ idle as well @ higher rpm , as I am useing a digital wur and it makes a difference for me. I didn't say it should be 30" on a 930,just that is what the mfg. sugested to do . I had a zork on it for a while and had it mounted on top of it about 2" from the turbo as Brian Bodart sugested to do and it worked fine on boost but was not real reliable @ less than about 950 rpm.
mark houghton 11-15-2009 03:20 PM
My misunderstanding...I thought it meant 30 inches before the open end of the tail pipe. If I include the length of the muffler....starting at the turbo...to the end of the tail pipe then you're right I probably have 30" as well (on my non-stock straight thru muffler). I realize it's just the manufacturers recommendation.
I also tune mine at both idle and on higher rpms/boost, at idle using both the AFR gauge and the old standby Gunson Gas tester for %CO. My whole point is that we should not discount mounting sensors (for monitoring purposes only) post-muffler and relatively close to the end of the tail pipe. Each application is indeed unique.
RarlyL8 11-15-2009 03:34 PM
Here is what we do for the zorks. Not much to work with. Idle readings can be iffy.
http://forums.pelicanparts.com/uploa...1258327849.jpg
I also have the O2 bung in the neck of the mufflers due to packaging and other considerations. A heat sink will protect your sensor while not affecting the readings.
http://forums.pelicanparts.com/uploa...1258328028.jpg
02fly 11-18-2009 11:35 AM
So hopefuly I can get some help here I've asked this quesiton on rennlist, I've got a B&B dual outlet which side do I put the sensor?
gsmith660 11-18-2009 05:28 PM
Post a pic you might be able to mount it somewhere on the muffler itself.
02fly 11-18-2009 05:33 PM
So it's ok to place it in the muffler?
gsmith660 11-18-2009 06:49 PM
You can put it in the exhaust any place you want so long as a few rules are met, one it must point up like at the 2 or 11 oclock position so moisture cant settle in the sensor it will destroy it and it must get full exhast flow no stagnant locations and it must be back from the exhaust oulet so outside air cant corrupt the reading. Thats why I said post a pic of your muffler and I am sure we can steer you in the right direction.
02fly 11-18-2009 07:33 PM
I understand I will post a picture, I just have to take off the bumper which is no big deal I'll have to do to install the sensor. I just thought someone may know because for some reason one side of the exhaust is hotter than the other which must be due to baffling and I wasn't ready to do the job right now but I thought while it was brought up I'd ask. I really do thank you so please don't think I'm being an ass, I try and ask allot of question so I'm informed when I make a decision. So anyway I'll post some pics this weekend.
Thanks Don
