C2 cylinders on earlier case
Anyone here with experience using C2T cylinders in an earlier case (e.g. 1986 3.3 case)? Assuming you used o-rings to seal, any issues?
Maxx
86 Ruf'd and rebuilt (sold)
Old 11-14-2009, 07:50 AM
Hi I have c2 cylinders on my 86 case I used the o rings and a thin coat of yamabond 17000. miles no leaks . I was told to check top of cylinder two head clearance.
Old 11-14-2009, 08:47 AM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
I lost a lot of my paperwork when my computer crashed, but the C2T P&C are the fully finned ones correct? If so, that's what I used on my rebuild (87). We used the o-rings (and possibly a copper gasket IIRC). I'll have to ask my buddy to be sure, but there is a certain method to installing them to prevent leaks.
Old 11-14-2009, 06:02 PM
mine are full fins no leaks and lots of use
Old 11-14-2009, 06:49 PM
Forced Induction Junkie
WERK I's Avatar
Yes, the C2T cylinders are fully finned. I used the C2T's in my '85 930, used the viton cylinder o-rings for the spigot bore and used the copper based shims to maintain the factory deck height. Be aware that the infamous cylinder/head oil seepage arose from these cylinder/head combination's in instances where no head gasket is applied. I had very small signs of that on my engine. I would recommend using either the factory gasket or have the heads and cylinders modified by Steve Weiner to get a perfect mating surface.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 11-15-2009, 08:02 AM
Thanks for the responses. Yes, I have the fully finned C2T Ps&Cs. The earlier case mating surface is different from the C2T case around the head stud holes. Similar difference around the heads. Just wanted to be sure that time has proven this setup to work well. Planning to use the viton o-rings and copper gaskets so seems that should work well.
Maxx
Old 11-15-2009, 08:37 AM
A930Rocket's Avatar
Oh yeah, we sprayed some copper type gasket maker on the copper gaskets to help prevent leaks.
Old 11-15-2009, 06:15 PM
Send a message via Yahoo to Lukesportsman
I love that spray for any solid metal head gasket. Even on water cooled engines I've had good luck at 14:1. Some say don't use it, but in my hands I'd rather than not.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v803996TT
Old 11-16-2009, 06:36 PM
WERK I's Avatar
Really? Has anyone else used the tacky copper spray on cylinder head gaskets? I would think that it would create inconsistencies in between the head/gasket or barrel/gasket or worse, crystallize and blow out.
Dave
Old 11-17-2009, 06:52 AM
