9dreizig's Avatar
Location: Reno NV, Bay Area during most weeks,, Kids still in NH
Send a message via AIM to 9dreizig
Going rich
Ok guys thought I'd start a new thread for this.. Here's the situation on my 86 stock 930
I have excellant fuel pressure
Can't find a boost or vacuum leak
Digital WUR
Starts fine and idles at 14.7 AFR - although is "hunts" or surges
What could be the cause??
Stuck cold start injector ???
Help!!
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 11-15-2009, 02:05 PM
mark houghton's Avatar
Do I understand correctly that it's hunting/surging at idle?
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 11-15-2009, 03:22 PM
9dreizig's Avatar
Yes Mark that is correct
Old 11-15-2009, 04:56 PM
Infidel
JBL930's Avatar
I thought most on CIS are around 12.5 ish at idle?
Jonathan.
87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines.....
Old 540 BMW, XB12S Modified, for being a total hooligan
Old 11-15-2009, 06:07 PM
Try running a bit richer at idle. Just a simple twist of the mixture adjustment screw. It seems these cars run better when on the slightly rich side. Can't hurt to try it....I run mine at 13.8 to 14.2.
Do you trust your AFR's as being accurate?
Old 11-15-2009, 06:09 PM
9dreizig's Avatar
what I'm trying to say is that it goes much richer when running but is idling ok except that it surges. when running it's between 10.0 and 13.5 AFR.. and I can't tune it out..
sorry for my not being clear
"Todd"
Old 11-15-2009, 06:12 PM
9dreizig, that was my experience before when my vacuum hose from digiWUR was plugged on the wrong place. If you disconnect the hose or don't have a good vacuum where the hose is plugged, your MAP on idle would be 0.9. On idle according to Unwired Tools, your MAP on the UTCIS software should be reading 0.4 - 0.6. If it is greater than 0.6, then the digiWUR would falsely assume that you are always accelerating and making the AFR rich (as analyzed by 911st on my problem before).
I also unplugged the stock oxygen sensor and tuned my car from there (Mark Houghton explained to me the benefit of this).
You may want to read this too: pages 7-13
http://unwiredtools.com/manuals/UTCIS_Application_Guide_A2.pdf
Old 11-16-2009, 03:57 PM
9dreizig's Avatar
930 thanks but the WUR is showing 0.5 at idle and is consistant with the boost guage.
"Todd"
Old 11-16-2009, 04:30 PM
tj930's Avatar
Sorry if I'm "stating the bleeding obvious", but this is AFTER the warm-up cycle has finished?
Do you hear big changes in the tone of the engine as the CP rises during warm-up?
Old 11-17-2009, 05:35 AM
9dreizig's Avatar
TJ, yes this is after the warm up cycle. Engine was starting ok and running fine during warm up ( although now that the temp here has dropped warm up needs to be fine tuned)
"Todd"
Old 11-17-2009, 06:42 AM
