CaptainCalf's Avatar
Originally Posted by speednut View Post
I just let it idle for a minute or two then pull in the garage,I also have a filter after tha scavange pump to catch any bits of coke that might be in the oil. (just for piece of mind)..
good idea on the filter!
Side note: do you have any pics laying around of how you supported/mounted the GT35r? I'm think I'll have to fab something up cuz I don;t think I will be able to use the original turbo mounting bracket due to the GT35r's 3" vband for hot side outlet vs old bolt up style on the oem mount.
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD
1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD
2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha
Old 10-12-2011, 09:35 AM
Mine uses the 4 bolt like stock,I just modified the original bracket.
Old 10-12-2011, 11:22 AM
Thanks, I may mod the oem bracket too so I can use it on the vband...nothing a cutoff wheel and grinder cant handle
Old 10-12-2011, 11:29 AM
wax105's Avatar
Originally Posted by beepbeep View Post
Small electric pump pumping water and oil-cooler would be perfect. Maybe even natural convection (without pump) would work. Whatever you do, don't try to "cool" it by passing oil trough cooling mantle.
+1 Specialy if you will be tracking the car, will greatly extend turbo life
74' Coupe 3.6 Track Car
VW passat avant 4motion 1.8T
CRG Kalifornia 125Rotax (Sold)
Old 10-12-2011, 11:44 AM
no track time here Wax, otherwise I'd be compelled to run something through the water jacket
Old 10-12-2011, 12:15 PM
TurboKraft's Avatar
Easiest way we've found:
We made 25, and maybe 3 fit correctly without modification because everyone's headers fit slightly differently, turbine flanges different thicknesses, turbine housings different thicknesses...
It's just a piece of thick steel strap with a 10mm hole in each end and bent about 60-deg. We usually use some stainless about 3/4"wide, about 1/8 - 3/16" thick. Really easy to make one when you mount the turbocharger, and get rid of that factory hanger. You're just trying to stabilize the turbocharger and headers as the car bumps and bounces down the road. It's also supported by the muffler and its bracket & strap.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 10-13-2011, 10:31 AM
Thanks Chris, I've said this before and I'll say it again. You Da Man!!!
Old 10-13-2011, 10:35 AM
Banned
Mamut, I'm planning on running oil to the turbo brgs using the oem oil pressure line/source and the scavenge pump to pull oil from drip tank back to the oil tank. A restrictor will be used on that feed line cuz the brgs only like to be sprayed with oil & not float in it, but I don't think it's a good idea to use the same pressure feed source for the water jacket too cuz it may rob you motor of oil pressure.
How do you have yours set up?
It all dedends where are you discharging the oil,if you use the sump can for both,( oil lube for bearings and cooling jackets) then you probbly overwhelm the capacity of the scavenge pump, so you will probably will need to restrict the oil to the jacket, it all depends in other factors like the turbo pump oil scavange capacity and type of main oil pump,(EG gt3 pump,930 pump,etc).,cheers.
Old 10-16-2011, 05:54 PM
Agreed, I'm just gonna leave those coolant ports open to the air and try to keep the turbo cool & lubed by spraying oil on the brgs.
Thanks!
RC
Old 10-17-2011, 07:18 AM
Yep !
Old 10-17-2011, 03:42 PM
