Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
one of the great unwashed
patkeefe's Avatar
Stock wastegate replacement ???
I am retrofitting my SC turbo convert with a 930 exhaust. I have two iterations of this. One is a set of OBX headers, which I have already done trial fitment of, and fabricated custom turbo support brackets, welded in the flange for my 38MM Tial wastegate, and plumbed all of the turbo piping for.
I also have a stock exhaust system from an '87 930, which fits reasonably close to the OBX stuff. One noticeable difference is that the turbo will sit about 1/2" lower on the stock 930 exhaust. The other is the wastegate location. I cannot really cut off the flange and put another 38mm flange on it, because I can't get the wastegate outlet on. I like parts interchangability.
What is the Tial (or other) replacement for a stock 930? I am leaning towards the headers, as they are much lighter. But, I also like the option of heat, as I did use the car occasionally in the colder weather. At least my 986 has heat and snow tires.
TIA
Pat
Patrick E. Keefe
78 SC
01 Boxster
Old 11-22-2009, 08:10 AM
The Tial 46mm is a direct bolt-on, and what most of us use as a replacement.
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3 w/MS3X, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 11-22-2009, 08:22 AM
Crotchety Old Bastard
RarlyL8's Avatar
This is backwards. The OBX stuff should fit reasonably close to stock. If it doesn't then nothing will line up right or fit.
You need a bigger waste gate, especially in a low boost application. Stock replacement for the 930 is 46mm. You will need to vent more exhaust to sustain 0.5 bar than higher typical 930 levels.
Old 11-22-2009, 09:01 AM
Gumba11's Avatar
The only wastegate to buy. Follow this link for some additional reading.
TiAL Sport.com
77 930 "P Zilla" 3.2 Litre w / EFI conversion
Old 11-22-2009, 10:13 AM
patkeefe's Avatar
I agree, but I had the OBX stuff ready to fit before I had the stock 930 exhaust ready. One of the drawbacks to having no point of reference on a retrofitted SC. Also, the support is custom, as I have a new Borg Warner with a V-band exhaust, and really can't use a stock 930 support bracket. I am going to try and find a 46 Tial for the stock HE setup. I will say, the Tial 38 worked well on the prior Rajay setup without any boost creep.
Pat
Patrick E. Keefe
78 SC
01 Boxster
Old 11-22-2009, 12:41 PM
RarlyL8's Avatar
Pat,
I may have an extra 46mm WG flange that you could make an adapter with to fit the 38mm unit on the stock J-pipe. If it worked for you previously then it should work now.
Old 11-22-2009, 02:21 PM
patkeefe's Avatar
Thanks Brian:
The problem is the 38 exhausts perpendicular to the valve cover face (the 930 is parallel), so I have no room to put the WG outlet anywhere. I don't want to chop up the stock setup. Wait, I think I have the spare I cut off the OBX headers, let me see if I can spin the WG.
I appreciate the offer!
Pat
Patrick E. Keefe
78 SC
01 Boxster
Old 11-22-2009, 02:52 PM
RarlyL8's Avatar
TiAL 38mm should be a v-band which would spin any direction you wish.
Old 11-22-2009, 07:52 PM
