9dreizig's Avatar
Location: Reno NV, Bay Area during most weeks,, Kids still in NH
Send a message via AIM to 9dreizig
Originally Posted by gsmith660 View Post
judgeing the eff. of your intercooler is geeky? To each is own I guess.
Yes it is,, but we're all geeks here!!!! Would love to see someone track them and compare intercoolers
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 11-25-2009, 07:33 PM
9dreizig's Avatar
Originally Posted by RarlyL8 View Post
I need one of these (intercooler in/out temp) gages as I plan to try out different intercoolers. Who has the best unit / price?
Hmmmm future new product from the RarlyL8 skunk works ??
"Todd"
Old 11-25-2009, 07:35 PM
7.0:1 > 11.3:1
Google Omega temperature products. Get a handheld dual input "K" meter ~$150(comes with a few .006" beaded thermocouples) also get a couple "K" 10' extensions. Insert the beaded thermocouples into the airstream under hose joints etc. Once you look at your charge temps you can used the gear for lots of other interesting temp measurements.
Old 11-25-2009, 08:06 PM
Crotchety Old Bastard
RarlyL8's Avatar
The market is completely devoid of a true bolt-on quality aftermarket intercooler for our cars.
I looked up the A/Spruce unit, thanks for the tip!
Old 11-25-2009, 08:15 PM
7.0:1 > 11.3:1
You might also look at pressure drop to complete the picture.
9dreizig's Avatar
Kind of a long winded "yes" Brian
Very cool BTW!!!
"Todd"
Old 11-25-2009, 08:20 PM
Happiest when Tinkering
gsmith660's Avatar
Thanks Todd, I do plan on gathering as much data as possible in the beginning I said putting this turbo on a 2.7 is all about risk and info gathering, just a note I got the tail sold despite the canuck that stiffed me.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 11-25-2009, 08:28 PM
ZLP ZLP is offline
Low Speed, High Drag
ZLP's Avatar
Originally Posted by drmatera View Post
ok, well you should be seeing well under 100*f at full boost with .5 bar. What does your intake air temp show?
I am running a Davtron as well with my 965 intercooler. The temps will vary with ambient air temp, boost, turbo, intercooler, and length of time on boost. Any turbo and intercooler combo can see over 100 degrees depending on the factors I listed. Typically I see close to ambient temps if only doing short pulls but on a low speed road course the temps will rise with heat soak and I have seen high temps well over a 100 degrees. Happy thanksgiving!
Old 11-25-2009, 11:12 PM
RarlyL8's Avatar
Where do you plumb in the probes? Will I need to drill and tap or add bosses?
Old 11-26-2009, 06:32 AM
gsmith660's Avatar
It will be fairly easy I think you should be able to add a fitting to the inlet and outlet plenums and that will give you the readings you need.
Old 11-26-2009, 06:56 AM
ZLP ZLP is offline
ZLP's Avatar
You will just need to drill. They are thermal couplings so no tapping. I put them on the back of both ends of the intercooler so they can't be seen and ran a wire loom up to the dash to keep it clean.
Old 11-26-2009, 07:40 AM
If evaluating different inter-coolers, I suspect pressure drop across the core at a given CFM or HP is another point of interest.
Old 11-26-2009, 11:30 AM
gsmith660's Avatar
I would think getting a gauge that you could mount in the car would not be accurate enough for measureing the drop across the IC maybe inches of mercury DP
Old 11-26-2009, 12:27 PM
Wer bremst verliert
JohnJL's Avatar
I've done it with normal MAP sensors. The one at the manifold connected to the ECU as normal and the dyno MAP sensor connected at the supercharger output manifold before the intercooler. Log both and compare.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 11-26-2009, 03:03 PM
RarlyL8's Avatar
I don't want to drill into the intercoolers. Sounds like drilling the stock intercooler up-pipe and the intake manifold is the way to go.
If you don't tap the holes how do the probes stay in place? Anyone have a picture of these probes? I didn't see any on the site I visited.
Old 11-26-2009, 05:47 PM
ZLP ZLP is offline
ZLP's Avatar
A loctite'd nut on the inside.
Old 11-26-2009, 10:04 PM
sjf911's Avatar
Looks like the best place would be the intercooler with lots of locktite.
M307FD-CD Digital Temperature Gauge | Davtron Inc
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 11-27-2009, 07:05 AM
RarlyL8's Avatar
Thank you for the link. How quickly do these probes react? If it takes 60 seconds to stabilize temp it is no good for the intended application.
Old 11-27-2009, 07:36 AM
ZLP ZLP is offline
ZLP's Avatar
The Davtron is instant.
Old 11-27-2009, 08:02 AM
R.I.P.
drmatera's Avatar
when i recorded my temps it was in the hi 80*'s outside and i had been doing a lot of driving and idling. On the first 3 gear pull the temps were in the mid 120*'s it wasn't untill the second 3 gear pull that the temps got to 134*. I would suspect on a road coarse the temps would get above 150*. Keep in mind my temp sensor is in the intake manifold, not the pipe or intercooler so some engine heat is transfered. The best comparison would be "whats the inlet temp while cruising vs. WOT?"
mine was 95* cruise - 134* WOT (15psi) anyone else care to share?
Old 11-29-2009, 01:25 PM
