Happiest when Tinkering
gsmith660's Avatar
intercooler air temp gauge
Anybody using a differential air temp gauge to measure intercooler eff ? Any recommendations?
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 11-25-2009, 10:50 AM
Andial makes one.
ANDIAL - Performance Parts for Porsche
Old 11-25-2009, 11:16 AM
R.I.P.
drmatera's Avatar
check out Davtron. I bought one from them over 16 years ago, still works great.
M301 Digital Temperature Gauge | Davtron Inc
Old 11-25-2009, 11:38 AM
Wer bremst verliert
JohnJL's Avatar
I use spare channels on my Adaptronic ECU to track both temps and pressures. Basic Bosch temp sensors on both sides.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 11-25-2009, 11:52 AM
An exhaust gas temp (EGT) gauge is a good idea to.
It monitors the accumulated effect of the Inter-Cooler efficiency, load, the motors thermal reserve, turbo's efficiency, and Air Fuel Ratios.
gsmith660's Avatar
The andial gauge is the same as the Davtron gauge only I bet it has a big price markup for the andial name on it Thanks to both of you for the suggestions the gauge and it is sold at aircraft spruceand also would fit beautifully where the ashtray would go. I would like to see others if possible like a analog cross sweeping typeI have seen but cant seem to find on the internet.
Old 11-25-2009, 11:57 AM
gsmith660's Avatar
Megasquirt has channels on the ecu also I believe to track temps. I am looking for 1 gauge with an in and out.
Old 11-25-2009, 12:00 PM
gsmith660's Avatar
good idea one to consider if I can find the room.
Old 11-25-2009, 12:01 PM
gsmith660's Avatar
The main reason I want to do this is to see if my intercooler is as effcient as claimed it is much smaller than the monsters you guys run but when I bought it many years ago Marty told me it was much more effcient than the stock intercooler. It will work fine for now as I like the way the install turned out for looks although the overall eff. probably took a hit since I didn't use gentle bends in the plumbing that is something I will take care of that later. What is the typical temp. drop across a intercooler?
Old 11-25-2009, 12:07 PM
full quack's Avatar
Send a message via Yahoo to full quack
Ok guys,
I get head temp., exhaust temp, & AFR's......but seriously.... intercooler temp is getting dangerously close to geekdom.
Mark
Old 11-25-2009, 12:09 PM
gsmith660's Avatar
judgeing the eff. of your intercooler is geeky? To each is own I guess.
Old 11-25-2009, 12:47 PM
R.I.P.
drmatera's Avatar
GSMITH660- check out my EFI post. I did some temp recording with no intercooler vs intercooler. At 1 bar your average K27 should be putting out roughly 200*.
Old 11-25-2009, 12:51 PM
Crotchety Old Bastard
RarlyL8's Avatar
I need one of these (intercooler in/out temp) gages as I plan to try out different intercoolers. Who has the best unit / price?
Old 11-25-2009, 01:03 PM
Wer bremst verliert
JohnJL's Avatar
At full-chat on the dyno and on the track I get a consistent 37* C at the inlet manifolds. Ambient temps of 30* C. 0.8 bar supercharged boost.
My intercooler is a Bell 3.5" core with a shrouded twin-puller fan underneath.
Having permenant gauges is cool but if you are just looking to benchmark the intercooler then you could do it as simply as logging both temps on Megasquirt and checking the difference. Not quite a scientific but close would be to do two back-to-back runs first with teh thermometer before the intercooler and another after.
Old 11-25-2009, 01:08 PM
gsmith660's Avatar
Ok cool, I am only running .5 bar for the time being.
Old 11-25-2009, 01:28 PM
gsmith660's Avatar
I'm going for the GEEK effect! Brian the the davtron is at aircraft spruce for around 250 with senders.
Old 11-25-2009, 01:34 PM
gsmith660's Avatar
I am going to run a temp sensor down in my heat wrap to see what temps my O2 sensor is seeing and then outside the wrap.
Old 11-25-2009, 01:35 PM
R.I.P.
drmatera's Avatar
ok, well you should be seeing well under 100*f at full boost with .5 bar. What does your intake air temp show?
Old 11-25-2009, 01:50 PM
gsmith660's Avatar
Dont know I haven't setup a gauge on this yet. Are you talking about in megatune? I dont think I have a sensor set up for this either.
Old 11-25-2009, 02:33 PM
I am using both spare channels on my Megasquirt to monitor 2 of... fuel pressure, any 1 of 6 EGT or pre-intercooler temp at any given logging sessions. But I really need 6 more channels
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 11-25-2009, 05:15 PM
