Glad you got it running and hope you get the wastegate working and get to drive it soon.
They look nice and I hope it they make more horsepower.
...there's probably more interest and suspense waiting on this thread than any of them right now!
Old 01-15-2010, 10:05 AM
More progress, and setbacks. I was able to reseat the wastegate so that it does not leak at idle. While I was under the car, I noticed that cylinder #4's tubing was not turning a nice golden hue like the other 5 cylinders were. I could touch the pipe and it was cold.
First I put a spare spark plug on the end of the ignition wire, held to ground, and observed spark. (more on this later). I installed a different used plug in #4, but still dead.
Then I pulled the injector and observed fuel spraying when I pushed the air plate down. I switched the injector with #5 for the hell of it, but still dead.
So having fuel and spark, I convinced myself that my valve adjustment may have left one of the valves too tight (it is an unheated garage, so the engine is COLD). But I rechecked 4-5-6 intake and exhaust and they were fine. #4 still dead.
So I pulled all the plugs, and conducted a compression test- between 115-125 across the boards, number 4 had 125.
What the heck- fuel, spark, compression and it won't fire even once? The header tube can be touched while the others are scalding hot in 20 seconds of idling. So back to the spark- I did have spark but the spark itself was not too impressive, almost hard to see in a pretty dark garage. More searching on PP and I learn a weak spark can jump across a plug in free air but potentially not fire under tension in a compressed cylinder. So I pulled wire #4 (Clewett wires with 14k on them) and got 2700 ohms of resistance, where I was looking for about 1500 [500 ohms per foot of wire].
I decided to use the dead cylinder #4 wire on the #5 plug, and put #5's working wire on the problem #4. AND GUESS WHAT? Now #5 doesn't fire (cold tube), so it must be the ignition wire, right??? But #4 still doesn't fire!!! So if I had a bad wire, I should have been able to "move" the problem to cylinder #5, which I did, but I would expect #4 to fire now.
If anyone is still reading this, you may be as frustrated as I am. The entire house reeks of insanely rich exhaust from all the retests, despite the garage doors being open since the car is backed in. I am done and moving into diagnosis by credit card mode- I've ordered a set of magnecor wires, cap, rotor, and plugs from our host on the prayer that some weirdness is going on with one of my wires and then (after all the manipulation) another one of my wires either crapped out or my distributor cap has something going on with the #4 post.
I am simply out of ideas. The parts should arrive Friday (CA-to-NY) for our host and I get another crack at this next weekend.
1986 930, 1969 Mach1, 2003 540 Sport, 2016 R1200RS
Old 01-24-2010, 06:23 PM
Crotchety Old Bastard
RarlyL8's Avatar
I feel your pain. If you read my post when installing the beta headers I had a similar set of issues. Tried to do too many while-you-are-in-there's at once which really sounds good in theory. Reality can be a bit less glamorous.
If you have a way to read AFR's check your fuel mixture. Mine went lean.
Old 01-24-2010, 06:38 PM
Forced Induction Junkie
WERK I's Avatar
Brian and gsxrken,
Should the headers be a "golden hue" when idling? Were the plugs wet when you inspected them?
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 01-24-2010, 07:02 PM
RarlyL8's Avatar
Yes 321 stainless turns a bronze color when heat cycled. One way to tell you have the good stuff.
Here is a picture of a client's muffler after a few heat cycles:
Old 01-24-2010, 07:51 PM
Boost Freak
Maxx1's Avatar
Thumbs up
Wow! that's a work of art!
82 Porsche 930 Euro, black, 31K miles.
Factory stock other than k27 turbo, B&B headers, GHL exhaust, Tial F40, 1 bar wastegate, MSD 6A ignition, 8" and 9" Fuch upgrade, H4 Xenon headlamps and a 930S steering wheel.
Old 01-25-2010, 03:34 AM
WERK I's Avatar
Brian,
Just curious really, but have you a reason why people choose to have their exhaust exit on the driver's side (like factory) when they can just as easily have it exit the passenger side? Seems it would save a whole lot of space.
Thanks. Great products, btw
Dave
Old 01-25-2010, 08:21 AM
Automotive Monomaniac
Emission's Avatar
Originally Posted by WERK-I View Post
Brian,
Maybe because you don't have to cut the lower valance? Just a guess...
- Mike
1986 - 930 Coupe / 2016 - BMW X5 xDrive35i / 2015 - Volkswagen Golf TDI 6MT / 2018 -Porsche 911 Carrera 7MT
Old 01-25-2010, 08:23 AM
WERK I's Avatar
- Mike
........but Brian sells the valances, with or without cutouts.
Dave
Old 01-25-2010, 08:31 AM
RarlyL8's Avatar
That is correct, the factory outlet is on the driver's side. Those with steel color coded valances are not so eager to move the exit pipe to the passenger's side. The fiberglass valances can be rattle canned to a close match which is what most folks do that purchase them. Others cut out the passenger's side to match the driver's side and get the dual out muffler or split the system with the muffler exiting the passenger's side and the waste gate exit on the driver's side.
Lots of options if you want to move the tailpipe, only one if you wish to keep the stock exit look.
As a side note there is no difference in performance and just a little difference in sound between the driver's vs passenger's exit tailpipe with my systems.
Old 01-25-2010, 12:23 PM
beancounter
jwasbury's Avatar
- Mike
Bingo!
That photo is of my car's @$$
I wanted a plug 'n play muffler. Did not want to mess with the valance at the time. If I did it again, I might choose the passenger side exit or maybe the center exit w/ wastegate dump alongside. Brian's systems are modular (AFAIK) so I'm sure he could sell me just the pieces I need to convert to one of the other configs if I decide to change it up.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 01-25-2010, 01:22 PM
RarlyL8's Avatar
Yes they are modular which alows plug and play tailpipes in many configurations.
Old 01-25-2010, 02:04 PM
I do have an LM-1 that I do not leave installed on the car but can do the cigarette lighter thing for checking my idle or recording a blast through the gears for AFRs. I have not installed it on this system yet due to the issues noted. The car hasn't been on the ground yet. When I have it hitting on all six cylinders, but before I reinstall the bumper assembly, I can re-baseline with this new setup. My guess would be that my idle mixture needs wouldn't change, but we'll see.
Old 01-25-2010, 02:35 PM
proffighter's Avatar
@RarlyL8
Why is the bend not one piece? It looks not that smooth around that bow, at least from this angle shown on pic
Anyway, nice parts your headers and mufflers
Roland
930 Turbo '81 Too many modifications to list
Old 01-25-2010, 11:22 PM
Originally Posted by proffighter View Post
@RarlyL8
to tight of radius on the 180 for the tooling
Ben
914-6 2.4s GT tribute.
914-6werkshop.com manufacturer of 914-6, GT, Conversion parts
Old 01-26-2010, 03:28 AM
RarlyL8's Avatar
There is another benefit of the 2-piece bend, it is a larger ID than the rest of the pipe due to the angle of cut. The bend is actually very smooth.
Old 01-26-2010, 03:57 AM
SUCCESS! I just got back from a no-bumper excursion with some rip-snorting passes on the Taconic State Parkway... it's probably a good time to lay low in the garage for a little bit.
The most noticeable thing is that first gear breaks the tires loose as the boost comes on, something it did not do before. It does come on earlier, which is probably why. I wish I had boost and RPM logging data to really bring to this thread, but my LM-1 only has AFR. I did have to richen it up a touch, as it was at 15.3 at idle; whether this was due to my tuneup and valve adjustment, or better breathing, I can't say. The new Magnecors, cap, rotor, and plugs finally lit up the #4 cylinder, and again I'll never know which component it was. I suspect it was the wires as per my findings documented on my earlier posts.
I love the sound, too. With the sixth cylinder running, it actually seems quieter than I first thought at idle, but it cranks it up when I'm on it. The wastegate dump just adds to the party when it pops off. It being January in NY, I've been driving my truck all winter and haven't driven a real car in months- it's awesome how quick this thing rips up to 100MPH. Not having driven it in months, I really can't comment on off-idle tip in improvements right now, other than it still sucks compared to any other car out there.
That's it for now. When I get it buttoned up (bumper, lighted license plate bracket wired up) I'll take it out real legal-like and get some non-boosted impressions. Right now I'm enjoying the sounds and smells of the car ticking down to room temperature in my garage, and enjoying a general sense of bonding with the car. It took longer than expected but I would recommend this setup to everyone with one of these cars.
Old 01-30-2010, 02:10 PM
zaidigonzo's Avatar
hey, is that a euro exhaust you just removed? if so, I need a J-pipe if you r interested in selling........ Thanks
zaidigonzo@yahoo.com
im in fl, north of tampa
1984 ROW 930 turbo with rarly8 exhaust, waste gate pipe and HEADERS
K27HFS TURBO, B&B IC, 1 bar spring,LEASK WUR with rpm solenoid, fab speed intake filter, front strut brace rennline. MOMO wheel, Innovative afr 16-1 gauge, custom 930 ELGIN cam
Old 01-30-2010, 03:28 PM
Originally Posted by billjam View Post
You could quite easily make a 9mm key by grinding down a 10mm key
You prob actually need a 9mm that gets ground down a little and hammered in tight to get them out
Old 01-30-2010, 03:53 PM
Sorry, we obviously way past that. carry on. BTW, Nice exhaust Brian
Old 01-30-2010, 04:01 PM
