Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Turbocharge a CIS 2.7
May be an old subject, but does anybody still make a kit for a CIS 2.7 motor like they did some 20 years ago?
Signature Phrase " CATCH ME IF YOU CAN"
1988 Porsche 930 "Squerly" Built by "Porsche Doc"
1974 Porsche 911 (2003 - 2012)
2000 Boxster S (2006 - 2008)
Old 11-29-2009, 01:20 PM
Happiest when Tinkering
gsmith660's Avatar
I dont think so but some have done it DIY. I would suggest scrap the CIS and go EFI and you will need an ignition that will give you boost retard the stock 2.7 dizzy wont do you any good there.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 11-29-2009, 02:08 PM
Porschephd's Avatar
The 2.7 unless rebuilt is not a stable platform. Personally I would start with a 3.0. The cases on the 2.7 require a lot of work to become reliable
Old 11-29-2009, 03:29 PM
gsmith660's Avatar
You can always take the safe route aw heck whats the fun in that! I did my conversion on a 2.7 mostly to learn how to tune the EFI and learn how to tune a turbo motor. In all honesty I will be putting together a 3.2 short stroke motor in the very near future and I will be very intrested to tear this motor down to see what adding the turbo did to it. My case had all the mods done to it so I am confident the case will hold together and I had a recent upper end done on this motor so the only real concern I have is preventing any detonation so I dont hole a piston. That is why I said that about the dizzy and using EFI over CIS as you will have the ability to tune the air/fuel ratios and if you go with a tuneable ignition (I went with EDIS controlled by my EFI computer) you stand a chance at a fun little motor I have had a blast driving mine it has good response off boost and when then the boost kicks in well it is a kick in the pants I would like to work it out so the boost comes in a little smoother but that will be the other motor. The jist of this ramble is you can do it it will be fun but I feel like I am rideing on a ticking time bomb although I would like to see my motor go the distance till I can get the other one built but it is a crap shoot. Good luck.
Old 11-29-2009, 03:49 PM
3 restos WIP = psycho
kenikh's Avatar
The 2.7 unless rebuilt is not a stable platform. The cases on the 2.7 require a lot of work to become reliable
Tell me about it - my turbo build is using a CIS 2.4T 7R case and required just short of $3K in case work to be a truly reliable platform for my small bore turbo.
Personally, I wouldn't turbo a 2.7 since I feel that the smaller spigots of the 2.4 mag case is paramount for reliability. After all, this is the case the 2.1RSR turbo used.
Any aluminum case is a MUCH better starting point, so if you want to build a mag case turbo, you'd better user really low boost or have a purpose for using one.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 11-30-2009, 09:08 AM
