Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Oil at intecooler
I have noticed some oil build up at the top of the intercooler inlet tube when pulling the IC. I have also noticed some at the airbox. Someone mentioned valve guides or turbo seal. Can you elaborate?
Old 11-30-2009, 12:32 PM
930gt-40r's Avatar
how much oil are we talking about? Some oil will make it into there through the vent lines coming from the tank normally.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 11-30-2009, 01:05 PM
Is there excessive oil smoke upon startup from oil sitting in the headers? My car had a bad oil leak/smoking issue where oil would drain down from the tank to the turbo and the headers. When I would start it after sitting for a few days there would be excessive oil smoke burning out of the exhaust and oil blown up into the IC. It turned out to be a bad oil return tube in the tank.
Old 11-30-2009, 01:29 PM
mark houghton's Avatar
See my comments.
Smoking issue w/'79 930
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 11-30-2009, 01:46 PM
The amout of oil in the upper rim of the tube from the turbo to the IC could probably be soaked up by a few cue tips. Nothing too drastic. I don't experience any smoking. I will say that my airbox was modified and reworked to recieve a K&N air filter which made for a spot where oil can build up in the bottom corner of the housing. I would have to say that after a full season of driving (relatively aggressive) there was a small puddle which I soaked up with the corner of a rag. Again nothing overwhelming but it is there.
Old 11-30-2009, 03:22 PM
