Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
P&c
I am selling a set of P&C for a 78-89 3.3 930 (911 turbo) at No Reserve. Somebody is getting an early Christmas present as I am almost giving them away.
Link
Old 11-30-2009, 03:15 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Looks like somebody might get a good deal.
Good luck with the sale.
Old 11-30-2009, 04:07 PM
e170drvr's Avatar
Are they new, or used? Add does not specify.
Eric
87 930 Coupe Red, K27S, Kokeln IC, Rarlyl8 Headers system, Tial 46MM, .9 Bar. "Lola"
81 911SC Coupe Guards Red, Stock. "Zippy"
Old 11-30-2009, 04:52 PM
930gt-40r's Avatar
who polished them? Who did the flame ring and the honing?
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 11-30-2009, 04:55 PM
It's obvious from looking at those they are not new, but it's not said they are anyway.
Those cylinders have been rehoned and cut for a steel sealing ring so the cylinder heads that go on them need to have a matching groove cut too, and it appears an exhaust valve relief has been cut into the piston crowns.
The skirts of the pistons have been positioned in the picture so you can't really see the scuff wear area.
It may be coincidence but this P&C set sounds alot like a set refurbished by JB Racing that I know of from a silver slantnose 930 in S. Fl that has an Alabama connection.
Good luck on the sale... anyone interested should know the clearances on these pistons and cylinders and ring lands, and that they are not new and are cut for steel sealing rings so the heads need to be cut too.
Old 11-30-2009, 05:09 PM
They came with a 930 I bought back during the summer out of Nashville. They are currently sitting in the original Mahle box but have been redone. I can take some pictures of the sides and back of the pistons if you like, just let me know.
I am going to sell my 78 turbo also in a week or two. This is an old pictures of it before I put the black rubber whaletail back on it.
If I can answer any questions about the P&C let me know.
Old 11-30-2009, 07:32 PM
mark houghton's Avatar
[QUOTE=rufporschecar;5040718]They are currently sitting in the original Mahle box but have been redone. I can take some pictures of the sides and back of the pistons if you like, just let me know.QUOTE]
What does redone mean? Just throwing a ball hone in and scratching things up, or something a bit more involved - like boring oversized with appropriate pistons included? Is everything used, including the rings and wrist pins?
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 12-01-2009, 08:26 AM
Honed the cylinders with specialty equipment for whatever they are made of nickel something, not with a regular hone. Cut reliefs into the exhaust side of the pistons to prohibit valve contact for a high lift cam or mis-shift. New rings, fully balanced the pistons, reconditioned the pin bores but same pins.
Old 12-02-2009, 12:06 PM
