9dreizig's Avatar
Location: Reno NV, Bay Area during most weeks,, Kids still in NH
Send a message via AIM to 9dreizig
Digital fuel distributor
So the recent threads regarding digital WUR and electronic ignition control has me thinking about the last piece of the puzzle, our fuel heads.. Ok and I'm staring at a $500 bill to get mine rebuilt.
So that got me thinking, how would you build one from scratch?? Assuming we have modern technology what would it look like ? Would we still need a sensor plate ? With an encoder on it ? A stepper motor controlling a valve for fuel flow ?
I'm thinking that this should not be all that complicated or expensive..
Anybody interested in undertaking such a project ??
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 12-02-2009, 07:26 PM
930gt-40r's Avatar
I say buy a Haltech and negate the use lol...
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 12-03-2009, 05:07 AM
beancounter
jwasbury's Avatar
Very funny...
Yep I think they already make a digital fuel distributor...its called EFI.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 12-03-2009, 07:39 AM
mark houghton's Avatar
Yeah, it's called EFI. But believe it or not, your concept has crossed my mind as a means to further tune CIS fuel distribution. Use a stepper motor to adjust the metering plate deflection in response to various inputs.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 12-03-2009, 05:48 PM
copbait73's Avatar
Carry this on out:
You eliminate the metering plate (it doesn't like radical cams).
Mechanically position the distributor head control plunger with your stepper motor.
Motor is controlled by hot wire flowmeter based processor
.................or just use EFI.
Old 12-03-2009, 07:10 PM
Just need a TPS & MAP.
The software for the D WUR could be adapted easily if going the steeper motor route. It would also adapt well to MFI gas or diesal for mappable tuning of the injection pump. Wide applications if they ever think about it.
I thought about this way to much some years ago to.
One other thought was to replace the fuel head with a battery of EF-Injectors plugged into the CIS injector lines and the existing fuel accumulator might be able to sooth the fuel delivery to work with the existing CIS injectors.
This would save a lot of plumbing and fabrication over a full EFI conversion.
Old 12-03-2009, 08:55 PM
930gt-40r's Avatar
Well- if you have to keep mechanical injection- keep it mechanical. How about using a Kuglifischer ( I must have butcherd that...) pump that is timed off the cams like the old school race cars did? In this instance you keep the simplicity (or lack thereof) of the mechanical setup without efi. Realisticly, these pumps are very expensive if you can find them at all, but it does get rid of the metering plate and such. Now this would be the "Speed density" version of the current CIS (CIS= mass air metering..) and would allow you to run whatever cams/turbo/intake/etc. you wanted to run.
Kris @ Tech9
86' 930/GT-40R Sold
Old 12-04-2009, 06:07 AM
I have wondered if one could pull the metering assembly and just mount a MFI pump on the pancake manifold.
Getting the pump to accommodate the turbo would not be un-doable. I believe one of the pump builders can add a boost-pot to the pump that with boost richens the pump. It works on the rack like the thermostat and altitude pot's do. As most turbo's run a mild cam A 2.2 T pump might be a good base.
The race MFI pumps i believe operate as a function of percentage of throttle opening and do not have a space cam to adjust by rpm. I believe they run pig rich at everything except WOT over a narrow peak rpm range. Last one I saw offered was around $15k.
Fun stuff. Me, I love CIS and getting it to work it's best. For less effort than we are talking about to increase the base compression, to get ideal AFR's, improved ignition settings, anti lag /compressor bypass valve , and boost sensing WUR's if set up right can make for a pretty responsive and decent running 930 that dose not leave much on the table.
Old 12-04-2009, 08:25 AM
copbait73's Avatar
The MFI is a technical marvel who's time has past. I keep remembering Mark Donahue's comments about how he worked with Porsche and Bosch engineers on the MFI to develop a drivable Turbo 917.
Back to the CIS fantasy, elimination of the metering disc opens up the most benefits. Back in the early 70s, a production car needing to meet emissions and having no digital electronics available the metering discs limitations were an acceptable compromise. Many components of the system are still perfectly acceptable, and compatable with serious power generation, this one never was.
Old 12-04-2009, 09:06 AM
Turbo Hooligan
I've thought about this, but for the time and money...nahh $1500.00 and I can megasquirt my car.
www.d-zug.com
blog.d-zug.com
All these guys do is drive too fast, work on cars, chase ******* and drink.. really no fun at all...
Old 12-04-2009, 02:33 PM
