R.I.P.
drmatera's Avatar
spark plug tool
what kind of spark plug socket are you guys using to get the plugs out? Last time I did it I borrowed my mechanics, but every socket I have seems to thick to get in there...... I don't recall noticing his being overly thin but it must have been
Old 12-03-2009, 09:48 AM
R.I.P.
drmatera's Avatar
ok, I just ground one down to near paper thin..... then i heard i could get plugs with 5/8 hex instead of 13/16
Old 12-03-2009, 11:01 AM
The spark plug removal tool that comes in the 930 tool kit has always worked the best for me as it is just the right length to clear everything and swivels slightly at the end to prevent crossthreading when reinstalling.
Anthony @ Voitureltd Bayside WI.
Old 12-03-2009, 11:11 AM
mark houghton's Avatar
Been there done that! One of these days I need to buy a standard plug wrench as found in the tool kits (unfortunately, I don't have no stinkin' tool kit that came with the car).
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 12-03-2009, 11:27 AM
The factory tool kit spark plug socket is by far the best. It's perfect and nothing else even comes close... because it's the perfect length, has a thumbscrew on the end so you can use your fingers to hand start the plug nicely, and it is flexible while having a spring around it to keep it straight while at rest.
It is meant to be used with the 10mm allen wrench that comes in the origonal tool kit as a handle, but a 3/8 drive 10mm allen socket on a 3/8 drive ratchet with a flex head works better since it's easier to manuver it around AC lines and whatever else is in the way.
Old 12-03-2009, 11:34 AM
Boost Abuser
LOWFAT's Avatar
+1 factory tool !!!
Old 12-03-2009, 11:44 AM
David's Avatar
I turned the socket down in a lathe.
2014 Cayman S
2011 Cayenne Turbo
Old 12-03-2009, 12:03 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
I gotta try the factory tool. I've always used a socket taped to a universal and 3" extension...
Old 12-03-2009, 12:21 PM
R.I.P.
drmatera's Avatar
HOLY CRAP, I feel like a bone head. I pulled out the factory tool kit and there it was.. and had the allen wrench with it. what a dope!
Old 12-03-2009, 03:08 PM
spence88mph's Avatar
It's great to see others using the factory tool, I always feel like a hack using mine but I can't image how one could be better designed.
'89 911 M491+Turbo
'89 944 Turbo
'88 928S4
'18 C63S Coupe
Old 12-04-2009, 06:49 PM
R.I.P.
drmatera's Avatar
the factory tool is awesome. i will use it always, and thank god i didn't switch to 5/8 plugs..
Old 12-04-2009, 08:08 PM
Smart quod bastardus
fredmeister's Avatar
Factory tool 100/ anything else 0!
its perfect for the job.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 12-06-2009, 10:22 AM
