Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
zaidigonzo's Avatar
1984 930 chain tensioner
I got a 84 930 that was brought to us back then and converted to "US SPEC". Is it for sure that since it is from year 1984 that it has the upgraded tensioner in it already?? I checked right front fender and it does have a radiator style cooler but no fan that I could see......
Also If I get new headers and exhaust, can I still use the current heat exchangers and delete the cat converter?
thanks.......very new to porsches
Old 12-06-2009, 10:56 AM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
The fan on the oil cooker didn't come stick until 1987.
Look for small oil lines going to the right and left timing chain covers. This will mean oil fed tensioners.
Your new headers should have the heat exchangers built on them. They will have open ends to duct engine fan air through them and to the hearer boxes under the car.
You should be able to use your stock or any other muffler to replace the stock muffler/cat.
Old 12-06-2009, 01:38 PM
zaidigonzo's Avatar
thank you!!
Old 12-06-2009, 01:51 PM
