nnn nnn is offline
nnn's Avatar
How do you tell EURO CIS?
Just curios if mine may be Euro..... Previous owner didnt know and I showed someone the other day and he thought it was........
1988 Factory Slant
Old 12-11-2009, 01:55 PM
Thats a USA fuel head and injector lines not a rest of world or euro CIS.
You can tell because it is a smooth cast aluminum fuel head, it has a pulse valve for the lambda emissions system, and it has the skinny USA injector lines.
There are a couple other small diferences in the top half of the casting but it's difficult to see them in that pic anyway.
The euro head is always painted black, has a rough finish on the exterior, is made of cast iron so it weighs several pounds more, and does not have fittings for the lambda pulse valve.
Old 12-11-2009, 02:13 PM
nnn nnn is offline
nnn's Avatar
Thanks...... This really is a great forum..... Long time lurker..
1988 Factory Slant
Old 12-11-2009, 02:17 PM
E-85 sippin drunk
turbobrat930's Avatar
JFairman is spot on.... That is definately a US fuel system
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-35RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Infidel
JBL930's Avatar
Another dead give away is the euro fuel heads are painted black
Doh...just noticed Mr Fairman already said that....
Jonathan.
87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines.....
Old 540 BMW, XB12S Modified, for being a total hooligan
Old 12-11-2009, 03:24 PM
mark houghton's Avatar
So.....Euro = better??? Or is it just a marketting scheme just like buying French milled soap, German beer or Scotch whiskey. If it was made off-shore in the "old country", it's automatically better. OK, I hate deceptive marketing - can you tell?
I presume Euro fuel heads flow more fuel. Is that the only benefit?
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 12-11-2009, 03:44 PM
Infidel
JBL930's Avatar
The euro one flows more fuel i believe
Jonathan.
Old 12-11-2009, 04:01 PM
E-85 sippin drunk
The presumption is that: yes, the euro fuel head and system flows more fuel. The injectors have a different part number, the metal fuel lines form the fuel head to the injectors are bigger and the fuel head is different. This is a comparison between a stock "US" system and a "euro or ROW" system.
I would venture to say that doing a fuel head mod to the US fuel head would give you the same results or possibly even more fuel then the stock Euro system. add in an adjustable or digital WUR, and you have the potential for around 400 to 450 hp at the crank ( with cams, twin plug, I/C. turbo, headers, and other mods).
You can get the CIS system to flow a crap load of fuel...but the problem is to get consistant A/F 's as well as drivability
Old 12-12-2009, 03:34 AM
Infidel
JBL930's Avatar
I sent my euro fuel head to IA to flow more fuel, he sent me back a modified US fuel head and told me it will flow 20% more fuel than the Euro one. I was led to believe the US ones can be modded to flow more fuel than a modded Euro head, not sure why, or whether that's true?
Jonathan.
Old 12-12-2009, 03:52 AM
Crotchety Old Bastard
RarlyL8's Avatar
Yes it is true that a US head can be modified to flow more fuel than the Euro head.
Old 12-12-2009, 07:57 AM
Doing some research but was wondering about the UTCIS-PT unit. Can't you add more fuel with this unit? Thanks
1979 Porsche 930
Old 12-24-2009, 03:44 PM
Infidel
JBL930's Avatar
You can only lower control pressure so far, which can be done with either the UT unit or with an adjustable WUR. When lowering control pressure further makes no difference you can raise system pressure to add more fuel, but only so far. Then if you are still short of fuel you can have the fuel head modifed for more flow.
If even more fuel is needed then you really want to be looking at EFI as you are getting pretty up there power wise, which will be creating a lot of heat and stress, and you will want better control of everything, not just fuel
Jonathan.
Old 12-24-2009, 10:48 PM
Infidel
JBL930's Avatar
Brian, the point i was trying to make was that i was told that a modded US fuel head will flow more than a "modded" Euro one. Not sure why that would be the case, if it's even true?
Jonathan.
Old 12-25-2009, 03:50 AM
totle's Avatar
Anyone have a picture of the Euro CIS to show the difference between euro and US?
Old 12-25-2009, 05:08 AM
Cast aluminum modified USA fuel head on the left and a cast iron Euro/rest of world fuel head on the right.
the part number tag of the euro head.
the IA/flowtech head is now part #007
Old 12-25-2009, 12:13 PM
RarlyL8's Avatar
This is a typical Euro fuel head installed:
Old 12-25-2009, 12:20 PM
I see so how much horsepower can the Fuel Head Mod support with a UT unit? Do the injectors ever become a bottle neck for fuel? How about the fuel pumps? When do they start hitting there limits? Thanks!
1979 Porsche 930
Old 12-25-2009, 12:44 PM
RarlyL8's Avatar
A modified USA fuel head can support ~425whp. The most I have heard of is ~450. Anything past 400whp takes a lot of tuning and modification. Adjustable WUR is mandatory.
The fuel pumps and injectors can support much more. The bottleneck is likely the air metering plate. The AFR see-saw of the WUR begins to degrade at the extreme ends of the operating range, off boost and redline. You get one or the other but may not have both.
Old 12-25-2009, 08:28 PM
totle's Avatar
Have a US 78' 930, and can see that it has the black euro iron CIS fuel head.
The engine is 930/61
Was the US distributer only installed in US california cars, or has mine been updated with euro fuel head?
Does unfortunately not have much history from seller.
Old 12-27-2009, 02:23 PM
RarlyL8's Avatar
The aluminum fuel head was not introduced to the USA until 1986. All 930's had the black Euro fuel head up until that point.
Old 12-27-2009, 02:46 PM
