Blackbird Pilot
Reaper930's Avatar
That's cuz it needs to be flat black dude...jeeez
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us
Old 12-14-2009, 06:52 PM
wurls's Avatar
Originally Posted by djdawson2 View Post
Sounds like you're looking at the same car as I have... green/tan '89.
Here's my .02:
Mine was obviously very well cared for. Sadly, I've owned a lot of 80's CIS cars from Audi and VW, and all have been finicky... sometimes bad cold starting... sometimes bad hot starting... sometimes both... and many times unpredictable vapor-lock in hot weather.
My 930 has been the exception to the rule. It starts instantly and seems to run perfectly under all circumstances, including extreme altitude and very hot temperatures. Honestly, I was *very* hesitant to buy a 930 or 965 simply because they were CIS cars (I still own 2 CIS Audi urquattros, and have plenty of reasons to be afraid).
Since buying it, I've driven it on several very long trips (1000+ miles). It has always performed perfectly, even the A/C. This from a car that had nearly 100k miles on the clock when I bought it. I can honestly say that I've been very impressed. It even uses less oil than the manual tells us it will use.
The only weird thing it has ever done has been related to the fuel pumps. On occasion, they will fail to start. Several attempts cures this, but it has been an annoyance. It is related to the signal from the CIS telling the fuel pump relays that the engine is running, but I have not chased it down, as it would be easy to jump the relays if I ever needed to.
Having spent a fair amount of time in some NA 911s (and recently a 993), I can say that the real difference would be a "daily driver" factor. I can't really imagine using a 930 in this capacity, whereas an NA 911 would fit that duty just fine.
I think you can also expect to find some "deferred" maintenance. Despite mine being very well cared for, it still had some loose suspension bushings and things that needed attention. It also had a failed oil cooler fan, and at nearly $500 for the electric fan, I can see why it was not replaced.
Power... well, I wouldn't go into a 930 expecting to be impressed. For me, it was all about the visceral nature of driving the 930, and naturally the flat out sexy look of the car. Since buying the car, I've installed RarelyL8's exhaust, a B&B intercooler, a K27 7200 turbo, along with a 1 bar WG spring. Even with these things, the car isn't what I'd call "fast" by today's standards. However, the car is very rewarding to drive in a way that other cars just are not.
I just drove an NA 993 from Denver to San Fran. While it was a very fun car, it just wasn't the 930. But again, the 993 was a car that would be very easy to use on a daily basis... and has plenty of poop to be considered fun:
If you decide to try the 930, I doubt you would ever be unhappy, unless the car has been neglected. I'm a sucker for power, and I still love the 930. The only things I think that I would have HAD to do were Brian's muffler and replacing the headlights. The OE muffler kills the engine, and the headlights suck. These are must haves, IMO.
By the way... that green color sure seems to avoid scrutiny from the police, and that hasn't bothered me a bit.
Good luck.
First of all, THANKS for all of your excellent advice!!! I have a few turbo questions though, and they may sound dumb. You mentioned CIS on your turbo...what does it stand for and what does it mean? Also, "bar" is mentioned all the time, and I think it has to do with the turbo, but don't know exactly how. If anyone can shed some light on this, I would appreciate it!
The turbo won't be used as a daily driver, nor is my current Carrera...it's just a nice weather day off pleasure driver.
The owner of the turbo I am looking at told me that he is ok with it being PPI'd at a reputable place, but makes me wonder a bit about his maintenance habits (even though the car has been meticulously maintained). I say this because he told me that since he has owned it the fuel guage hasn't worked properly, and he hasn't ever fixed it. Everything on mine works 100%.
As well, the turbo owner told me that he did an upgrade to it in the wastegate section. What would an upgrade there do with the car, and how will I notice it?
Again...thanks for all the help/info guys!
I'll keep you all in the loop for my first turbo acquisition process!!!
Cheers!
Wurls
1995 993 Coupe
Old 12-14-2009, 07:24 PM
Send a message via Skype™ to djdawson2
CIS = continuous injection system... it is an early generation of Bosch fuel injection, and commonly known to be... um... less than excellent, and doesn't typically respond well to engine mods.
Bar = pressure, turbo pressure or "boost" in our world. 1 bar = 14.7 pounds per square inch. Stock boost level on a 930 is .8 bar. Typical mod is to increase it to .9 or 1 bar. The turbo itself is what forces induction on a turbocharged engine... and the compressor ("cold side") is driven by exhaust gas flow from the engine being sent through a turbine... known as the "hot side" of the turbo.
An "upgrade on the wastegate section" probably means that he changed the wastegate spring. Changing this spring is what raises the boost level from the stock .8 bar to something higher.
None of this is as complex as it might sound. It's an NA engine with a hairdryer.
Old 12-14-2009, 07:53 PM
Turbo Hooligan
then she wouldn't be the ying to blackies yang...but it would be pretty sweet to see a squadron of flat black RS71's at a future palooza!
www.d-zug.com
blog.d-zug.com
All these guys do is drive too fast, work on cars, chase ******* and drink.. really no fun at all...
Old 12-14-2009, 08:14 PM
Turbo Hooligan
CIS is good till a little over 400rwhp, and for making killer fireballs on deceleration!
www.d-zug.com
blog.d-zug.com
Old 12-14-2009, 08:15 PM
wurls's Avatar
Originally Posted by mark '87 930 View Post
For a Canadian car with that much mileage, and it's an '89, yes, that's a steal for sure. When I looked for mine a few years ago, it took some time and there was nothing in Canada at the time. I wish I had the opportunity to purchase a 5 speed, but I was good with the deal I had with my '87.
Best of luck with your decision.
Mark,
When you say that the 89 I'm interested in has "that much mileage" do you mean it has a lot, or not many miles? It has 110,000km (69,000 miles). I kinda thought that was on the higher side...but maybe I stand to be corrected.
Hey Mark, drop me a PM and we'll exchange emails (if you want). It would be nice to have another turbo owner close to where I live that I can get info/advice from.
Cheers n beers!
P.S. What is a DE car? I have NO idea what it means when I read it on posts!
Wurls
1995 993 Coupe
Old 12-15-2009, 07:13 AM
Canucks Fan
DE = Driving Event I think , Track day or driving school
Old 12-17-2009, 06:35 AM
