gavinc69's Avatar
Definition of acceleration
Got this as an email today and thought you guys would appreciate it
One top fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 4 rows of stock cars at the Daytona 500.
It takes just 15/100ths of a second for all 6,000+ horsepower of an NHRA Top Fuel dragster engine to reach the rear wheels.
Under full throttle, a dragster engine consumes 1-1/2 gallons of nitro methane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.
A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster's supercharger.
With 3,000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition.
Cylinders run on the verge of hydraulic lock at full throttle.
At the stoichiometric (stoichiometry: methodology and technology by which quantities of reactants and products in chemical reactions are determined) 1.7:1 air/fuel mixture of nitro methane, the flame front temperature measures 7,050 deg F.
Nitro methane burns yellow... The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
Spark plug electrodes are totally consumed during a pass. After halfway, the engine is dieseling from compression, plus the glow of exhaust valves at 1,400 deg F. The engine can only be shut down by cutting the fuel flow.
If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
In order to exceed 300 mph in 4. 5 seconds, dragsters must accelerate an average of over 4G's. In order to reach 200 mph (well before half-track), the launch acceleration approaches 8G's.
Dragsters reach over 300 miles per hour before you have completed reading this sentence.
Top fuel engines turn approximately 540 revolutions from light to light! Including the burnout, the engine must only survive 900 revolutions under load.
The redline is actually quite high at 9,500 rpm.
Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimate $1,000.00 per second.
The current top fuel dragster elapsed time record is 4.428 seconds for the quarter mile (11/12/06, Tony Schumacher, at Pomona , CA ). The top speed record is 336.15 mph as measured over the last 66' of the run (05/25/05 Tony Schumacher, at Hebron , OH ).
Putting all of this into perspective:
You are driving the average $140,000 Lingenfelter 'twin-turbo' powered Corvette Z06. Over a mile up the road, a top fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line and pass the dragster at an honest 200 mph. The 'tree' goes green for both of you at that moment.
The dragster launches and starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds, the dragster catches and passes you. He beats you to the finish line, a quarter mile away from where you just passed him.
Think about it, from a standing start, the dragster had spotted you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1,320 foot long race course.
...... and that my friend, is ACCELERATION!
Old 12-17-2009, 10:45 AM
E-85 sippin drunk
turbobrat930's Avatar
yep, that was a cool posting!! It is amazing the engineering and development that goes into one of those cars....
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-35RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 12-17-2009, 11:02 AM
R.I.P.
drmatera's Avatar
and seeing them go down the track in person is otherworldly. nothing short of a rocket launch will compare to the feeling of sitting in the stands as 2 of those machines rip down the track 80ft from you. Your vision distorts as they go by
Old 12-17-2009, 11:17 AM
930gt-40r's Avatar
I like the fact of the nitro methane being compressed to an almost solid state- thats amazing
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 12-17-2009, 05:12 PM
full quack's Avatar
Send a message via Yahoo to full quack
Back in the early eighties, my friend & I would go to the Seattle International Raceway several times a month to watch the rails & funnies run at night. Back then the only thing between you and the cars, was a 10' strip of grass & an Armco barrier.
When under the lights & between runs, we would sneak up right next to the Armco barrier & lay on the grass at about the 300 foot mark. That would put us with literally 8' from us to the cars. Now the cars were not as fast back then, but the sensation was intense! Ah the good ol days.
Mark
Old 12-17-2009, 08:18 PM
Manassas, VA
lucittm's Avatar
I rode in a two-seater pro dragster in Feb of 2008 at Firebird in Phoenix. It was called "Ride with Roy" and if you ever get the chance - do it. The driver let off about halfway because he didn't want to use the extra fuel (the "ride" is 1/8th mile but he took us the full 1/4). The ET was 9.642 at 116.41 and we were just coasting.
Even though he told me to put my helmet back into the roll bar, it still slammed me back as if I had been kicked by a horse.
It was great!
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 12-18-2009, 02:42 PM
