Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
1979 930's Avatar
a sunday present!!
I walk in the garage today not wanting to play with my toys.
but hear a humming sound coming from the front of my 1987 carrear
sounds like the fuel pump, but key is off!!
turns out to be fuel pump, key still off.
HELP PLEASE WHY WOULD IT BE RUNNING.
Thanks ed
Old 12-20-2009, 01:39 PM
MikeD930's Avatar
Sorry I can't help about this one but may I suggest to disconnect the battery immediately (if you have not done so). Hope others can chime in and help quickly.
MikeD
'87 930
Old 12-20-2009, 01:46 PM
pull the fuse
Bryan O.
77 930
08 Boxster
14 535i M Sport
Old 12-20-2009, 01:48 PM
mark houghton's Avatar
Short or fault in the ignition key, the micro switch at the fuel distributor control arm, or perhaps the infamous yellow relay. That's all I can think of.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 12-20-2009, 03:07 PM
On my '87 the 2 red fuel pump relays in the front of the car are hot all the time, even with the key off and removed.
My guess is the front fuel pump relay's points are frozen together in the on position. Especially if only the front pump is running.
If it was any of the other relays, switches, or alarm systems causing it then both pumps should be running.
Old 12-20-2009, 05:24 PM
1979 930's Avatar
just the front pump is running. pulled the battery cable till next play day!
damn thing was just sitting in the garage and started running.
where is the yellow relay.
Old 12-20-2009, 07:06 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
In the engine bay. Left side by the tail light. Might have to remove the cover off if you have it on.
Old 12-20-2009, 07:22 PM
1979 930's Avatar
fuel pump relay under the drivers seat had water in it at one time!!
all done back on the road,
fishing for the last week
Old 01-27-2010, 08:42 PM
Max Sluiter
Flieger's Avatar
Holy Mackarel!
Crickey, that's a nice fish.
911S
1971 chassis, 2.7RS spec MFI engine, suspension mods, lightened
http://www.flickr.com/photos/max_911_fahrer/
Old 01-27-2010, 09:04 PM
