Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
zaidigonzo's Avatar
blownsix bolt on IC? thoughts on this one?
called kokeln, called andial. None available. Kokeln has none for the next 4-6 months. Andial has to build me one and said maybe in march 2010.
Found blownsix website and it has one to order on line. A bolt on one that retains A/C. Are these any good? All Im doing is replacing to 1 bar spring, K27 7006 turbo and rarly single outlet pipe with matching wastegate,.....
Blownsix Design
1984 ROW 930 turbo with rarly8 exhaust, waste gate pipe and HEADERS
K27HFS TURBO, B&B IC, 1 bar spring,LEASK WUR with rpm solenoid, fab speed intake filter, front strut brace rennline. MOMO wheel, Innovative afr 16-1 gauge, custom 930 ELGIN cam
Old 12-21-2009, 08:29 AM
Garrison's Avatar
Do a search on Blown6... there are some that have had no issues, and there are some that had all kinds of fitment issues...
Kokeln, Garretson, Andial and even B&B are the ones that I have heard will fit with little to no effort.
1996 Porsche 911
2013 BMW 335xi - Wifes car
2007 4Runner - 4x4 for Colorado snow
Past: 1988 Venetian Blue 911 Targa, 1983 Black 930, 1984 Black 911 Coupe
Old 12-21-2009, 10:01 AM
Send a message via AIM to Chuck Jones
I have a B6 installed...it took some modification to the mounting tabs...the holes were off center and required me to have the holes welded shut and re-drilled. I had one fellow do it who didn't know what he was doing and kept blowing off the up pipe fitting. Took it to IPB here in Sacto' and they did it right. The intercooler is really quite nice and does a good job of cooling, but it was a bit of a hassle getting it to fit. I had to trim the plastic shroud, but found another in case I want to retro to stock. I slit a piece of black hose and ran it around the edge of the shroud to seal against the intercooler. It's worked well here in the Sacto' valley where summers are hot. I haven't tracked it so I cant' address how well it would work under heavy load for a long run....heat soak etc. I paid $1K for it then paid another couple $400 plus for refit so you may be better off getting one that's a drop in and run. Maybe B6 has addressed the fitment issues by now...but it was NOT a plug and play fitment as was advertised.
1987 factory Slantnosed 930 Cabriolet/Guard's red
2002 Midnight Blue 996TT X50
1999 Iris Blue 996 (Dash fire burned and totalled 9/07)
Old 12-21-2009, 12:15 PM
zaidigonzo's Avatar
thanks. Sucks cause I thought I could just get it and put it on.....
Old 12-21-2009, 01:09 PM
same deal as lots of the bargain parts out there...you can get a deal but end up with more install problems. it is worth it if you are handy sometimes.
Bell intercooler is who you should chat with, they make them for about $1500 to your specs. But you need to provide the pattern usually for them to custom make it.
Old 12-21-2009, 02:10 PM
I just purchased a Kokeln from FVD Brombacher (real estate education airline tickets at us.com) in Deerfield Florida. I searched for three months with no luck and found them on the web. The IC was shipped over from Germany and at my house in 2 weeks. At the time they said they had two which I have one of. You may luck out and get the last. Cost 2G complete kit.
Old 12-21-2009, 03:36 PM
sorry about the bum website above
Old 12-21-2009, 03:37 PM
E-85 sippin drunk
turbobrat930's Avatar
I could not agree more... Call Bell Intercoolers.. speak with Gerhart. I will bet that someone with a Kokeln I/C will need to supply you with a set of measurements. Give them to Gerhart. Two weeks later, it will show up at your doorstep.
I ordered a very thick, full bay I/C, and mine was a tad under $1400.00 shipped to my door. Excellent to deal with, and a very high quality finished item. Here are a coouple of pictures of Bell's quality. I know this I/C is not the right one for you, as its full bay, and made to be used with the 3.2L intake...but you will get the idea. The second picture is shown next to my old kokeln I/C...which has been gone for awhile now....
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-35RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 12-21-2009, 03:53 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Does Bell make a full bay IC for a CIS car? I would think by now, somebody has done it.
Old 12-21-2009, 05:57 PM
E-85 sippin drunk
I would think that they could just come up with a different end tank to use.... one that has a center discharge. I dont think it would be that hard....
Old 12-21-2009, 05:59 PM
MikeD930's Avatar
turbobrat,
Did you had to add/weld mounting brackets on your Bell IC? I don't see it in your pic. Regardless, that IC is high quality for its price.
MikeD
'87 930
Old 12-21-2009, 07:20 PM
Blackbird Pilot
Reaper930's Avatar
Call Bell IC - you need one of those - great cores, huge experience...they are THE name besides secan ($25k cores)...
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us
Old 12-21-2009, 09:50 PM
E-85 sippin drunk
Originally Posted by MikeD94 View Post
turbobrat,
Yes, I have to make the I/C mounts, weld them onto the I/C, and them bolt it onto the car. They are not that hard to build, and will look tons better that the mounts that come with the Kokeln...
Old 12-22-2009, 02:57 AM
Old 12-22-2009, 07:09 AM
petri's Avatar
I have BlownsixDesign 930 Full Width Race Application mounted in my RUF BTR and I've been very happy with it. Even if they don't sell it as "bolt on application", the fitment wasn't too difficult: My suggestion is, you would get this one fit just with right size rubber hoses and one support arm in the right side (you can make it easily from aluminum plate). When mounting just loosen the air intake bolts, mount the intercooler and then tighten the intake bolts, and there it is.
You can either stick with the existing dump valve or change to some more aggressive pop off application like Tial or something.
Garage: Strosek 911 RUF BTR|Strosek 911 3.6 rat RSR|Strosek 928SR|928S4R|928S|996C2RSR...and more... Altogether 11 Germans - 3 Italians - 2 British
Old 12-26-2009, 01:22 AM
zaidigonzo's Avatar
if you dont mind my stupid question, what does the improved pop off valve from Tial do better than stock. Im in process of doing IC upgrade from B&B stock size and while Im there I could change that pop off if it helps me with anything better than stock. Car also getting K27 7006 and rarly exhaust and waste pipe, stock euro heat exchangers. This car was retrofitted in 84 to Us emissions specs so I dont know what other things are in there that could affect things. I dont know what lamnda thing is but I assume it has it since it has cat converter and sticker on engine bay saying it was made compliant to US emissions by some company
Old 12-26-2009, 03:23 AM
zaidigonzo's Avatar
Old 12-26-2009, 03:24 AM
Although I posted that the half bay BlownSix intercooler was a bit of a hassle to install, I am informed by a number of the guys who bought the full bay version....that it was a much simpler install...and most of them seem to be very satisfied with the performance of that version.
I kept my AC which is why I went with the half bay model.
Old 12-26-2009, 11:49 AM
Smart quod bastardus
fredmeister's Avatar
overall I like my B&B half bay intercooler. A little trouble fitting it up in regards to the aluminum shrouding that seals to the wing, but good quality and only minor machining issues with the mounting bosses. Basically the tapped holes were off center of the cast bosses quite a bit, but nothing required rewelding or retapping.
I would like to see some data presented on pressure loss and thermal efficiencies of all the units out there.
Other than claims of 250% greater surface area over stock intercooler, there is not alot of hard data i have seen to compare one brand with another.
hope this helped you.
Fredmeister
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 12-28-2009, 07:23 AM
Me like track days
Craig 930 RS's Avatar
Try the RUF unit. EASY install -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 12-28-2009, 10:07 PM
