Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Show me pics of your tt 930 exhaust
Show me your pictures of your 930 with twin turbos. I'm trying to get ideas on how to build my exhaust system. Has anybody used 993 heat exchangers?
Old 01-05-2010, 09:27 PM
There is all kinds of pics of the systems that Raely L8 sells with the 993 H/E on here . Do a search.
Old 01-06-2010, 06:18 AM
I have a medium built 3.4 twin turbo ( near 500 HP @ 1.0 bar ) that the intake / exhaust systems were set up by Jarvis ( highly regarded FL tuner) and they used the 993 header set up. I would think it solves lots of problems if you are not looking to build for ultimate track car performance.
Anthony @ Voitureltd Bayside WI.
Old 01-06-2010, 06:36 AM
Wo ist die Rennstrecke?
DonE's Avatar
The 993 is not so bad for DE's or moderate track use either... Good suggestion.
Old 01-06-2010, 08:19 PM
You read my mind as that is what that set up will be used for ( if I ever get it finished). We did it that way so whoever gets it ( after I play with it a little) and drives DE or vintage will not have to rebuild after every 80 hours or so.
Old 01-07-2010, 05:41 AM
rsrfan's Avatar
Damn Tony, I NEED that tail for my 934 conversion. Is even the right color...
JP
86 930/4 tribute beasty
81 sc beach beater
89 targa black betty
Old 01-07-2010, 09:59 AM
What color one do you have to swap? The Porsche racer I got it from said it was from a real one. Could be true as it is very old with a smaller air intake insert installed well after the rest of it was built. Has a black Kevlar horizontal wing which is also well aged although still race presentable. Or better still get the whole chassis as I would then get the IMSA chassis currently on Ebay that is currently being discussed on this forum "track car". I just want something to put my running gear into, not compete in the PCA or Vintage classes, as that would take less time to complete.
Old 01-07-2010, 01:35 PM
Crotchety Old Bastard
RarlyL8's Avatar
This is an old thread but may be of value to you. I started it when first learning how to go about twin turbocharging the boxer 6.
EVIL ENGINE goes Twin Turbo - Your Chance to Design the 930tt Exhaust System
Old 01-07-2010, 03:55 PM
sub'd.
Old 01-08-2010, 07:19 AM
DPHANS
DPHANS's Avatar
Maybe this will help?
DPHANS
Only Dp 935 cars for me : Dp 935 2.8LTwin Turbo and a Dp 935 Cab 3.0L Twin turbo. Dp 935 3.0L coupe
Visit Youtube= DP935 MANTORP
Old 01-09-2010, 08:55 AM
Fun!
Old 01-09-2010, 03:58 PM
totle's Avatar
DPHANS, please post more pics of your twin turbo setup.
Old 01-10-2010, 04:52 AM
Note the turbo's and mounted a little up and drain into the chain housing.
Makes valve adjustments a lot easier than with hanging them on the sides though the header volume is increased this way.
Starting with a set of RarlyL8's NA short tube SS equal length headers would work well.
Old 01-10-2010, 07:31 AM
Forced Induction Junkie
WERK I's Avatar
DPHANS
Are those 993 turbochargers (K-16's?) with integral wastegates?
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 01-10-2010, 07:40 AM
DPHANS
DPHANS's Avatar
Sorry for my late reply.
The turbos are TD 04/ 12 with integral wastegates. This is a modern turbo.
made by Mitsubishi. And they works super.
DPHANS
Old 01-11-2010, 01:32 AM
juicersr's Avatar
DPHANS
Hans, is this the 2.8 or 3.0 motor?
Are you running the oil feed lines to the turbos from the cam lines?
More pix please!
'79 930/934 replica
80 RSR-look(Now in Sicily)
914/6 2.7 (Projekt 908/3)
1965 Karman Ghia-Class winner 2007 Carrera Panamericana/Ducati 900ss/GhezziBrian STW
D-Zug Produkte/D-Zug.com
Old 01-11-2010, 07:25 AM
DPHANS
DPHANS's Avatar
More pix please!
Hi J.
This is the full magnesium 2,8 engine,
You are correct. the oil feed line is coming from the cam supply. Just keep it simple.
DPHANS
Old 01-11-2010, 08:34 AM
WERK I's Avatar
Hi J.
DPHANS
DPHANS,
Thanks for the photos. Additional injectors (2) feeding into the throttle body?
Dave
Old 01-11-2010, 09:50 AM
juicersr's Avatar
DPHANS,
I think he's using a 928 fuel head with the two left-over injectors being used for enrichment.
Simply brilliant. Garage hot-rodding at it's finest.
'79 930/934 replica
Old 01-11-2010, 09:57 AM
DPHANS
DPHANS's Avatar
Yes J
You are correct,, It cant be to much with injectors (SAAB) + I have a homemade enrichment sytem, 2 electrical injectors one is set at 0,85bar and one is set at 1,15 bar, all mounted on the plenum. (Its programmed by my IBM 486).
DPHANS
Old 01-12-2010, 10:14 AM
