Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
RRD RRD is offline
997 turbo crankshaft
Can a 997 turbo cranshaft be adapted to a 3.2/930 case? I do not see a countershaft gear on the crank... so how are the cams driven?
Old 01-07-2010, 06:23 AM
930gt-40r's Avatar
I am pretty sure that this could fit into a 930 case- I have a 993TT unit in mine, and the guy I got the crank from has a 996 gt-3 crank in his 993TT- then the 997 turbo is roughly the same thing as a 996TT. So it should work. The reason you dont see the gear is because the guy simply removed it as they are not integral, so you could take the ones off of your 930 crank and slip them on* (I am pretty sure of this, not 100% that they will fit...) I also believe you can get away with using the 997 rods as well, but I dont know about the wrist pin bushings- you may have to have them pressed for units that fit your pistons' wrist pins.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 01-07-2010, 08:54 AM
RRD RRD is offline
997
Thanks, just found a couple of pictures that show it like 993tt bottom end.
Does anyone have a con rod center to center length for this engine? I'm trying to get some data for pistons required.
Thanks all.
RD
Old 01-07-2010, 09:05 AM
