Don I had a lot of problems with my car due to a tranny swap gone bad. Been working on it every chance I get and have made good progress as it is running much better now.
It was my plan to hit the dyno as soon as the headers were installed. That was at least 3 months ago. I did have one afternoon of driving the new headers before disaster struck and my butt dyno was very impressed. The off-boost throttle response and torque really improved as expected. The car ran like a 3.2L Carrera off boost which is really good for a 930, ha! I have one final problem to chase down before we hit the dyno. I also need to hook up the LM-1 and see what is going on with my AFRs. One interesting note that I did not expect - my idle mixture was pretty far off after the headers were installed. It is expected to tweak the idle mixture when adding headers but this was a pretty big tweak. I am waiting on feedback from clients to see if thier idle mixtures were also affected. This is something you don't hear much about when adding bolt-on mods that needs to be addressed for the DIY guys. |
Yes it went lean enough that the engine would not run correctly. It would start perfectly and quickly degrade as the engine warmed and the WUR pressure rose.
Checking all the vacuum/pressure hoses reveal anything? I wouldn't that big of a swing in your mixture after changing headers either. When I went with the B&B headers changeover from the factory exhaust, I had to go 1-click rich to bring the mixture in line. Nowhere as efficient as your header setup.......
Yes one click is probably typical. I tore the entire CIS apart looking for leaks and problems. Very long story short there was nothing significantly wrong with the CIS. The remaining issue was the idle mixture, a simple adjustment.
In addition to welding in a divider, you need to keep both sides isolated without a crossover (you need two wastegates). Also, the individual pipes must go all the way to the turbo (no collector). I don"t recommend it for the street. The divider doesn"t last too long.
http://forums.pelicanparts.com/uploa...1263329596.jpg |
funny my divider is holding up well though my car is not a 24 hour car like the 935's |
Speedy, you are describing an optimum split plenum header. An optimum split plenum system has no secondaries; each primary terminates at the turbo inlet. VERY difficult design on a 930 but I have seen one with my own eyes. The wastegate setup is awkward to say the least.
I have a dual wastegate option for the split plenum systems we produced in the past and I plan to do the same thing with these headers. The dual origin single waste gate pipe is replaces by a short expension to each secondary elbow and the secondaries remain separated terminating at the turbo flange. This is not a perfect split plenum system but it is a nice compomise for 930 constraints. |
This "piece of museum" as you describe it is the most efficient header system ever designed for the 930. Respect my friend SmileWavy ;)
What's the origin of this header?
Thanks |
http://forums.pelicanparts.com/uploa...1263335311.jpg |
Der museum piece:
Looks like it was a split system and someone cut a WG off one and cut out the partition between each bank. Nice longer radius turns out of the heads and a smother bend up to the turbo than a 930 (had to flip turbo to work). |
Porsche racing department. That system was fitted on the 934 (the example shown above is somewhat mutilated).
Here is a better picture of the 934 headers stolen from Flieger's photo page.
It has some positive attributes but I probably would not say it was near perfect. It is very sexy! http://forums.pelicanparts.com/uploa...1263338969.jpg |
My photos are free for all to see in high-res SmileWavy
Porsche 934.5 Racecar - a set on Flickr http://forums.pelicanparts.com/uploa...1263340444.jpg |
Zeb,
These make me lust! Quote:
Finally, some real turbo headers - short, straight and right to the point. Those are worth building a car around....
Thanks for the pic. |
And the best part is that they are simple- I could likely fabricate a set of the 935 headers...
I bet I could "stitch" weld using SS wire in my MIG. Only an experienced eye could spot the difference, but since its under the car, who cares. |
When I twin my car someday this is the system that I will use.
Not as short and to the point as 993tt headers though! Bigger bore no doubt, also has exit for external wastegate, but surely if short and simple is the goal then 993tt size/style ones are going to be the best? Also almost equal length
Something like this? http://i139.photobucket.com/albums/q...993TT_11_1.jpg |
These are the same style (copies of actual original 935 headers) that I will be using on my setup in the next week or so. Going to swain coat them white
http://forums.pelicanparts.com/uploa...1263347797.jpg |
Gab- Where does one acquire these pieces? Im not in the market yet, but likely next year I will want to switch it up a little bit. White would look nasty on these, kinda like the old ferrari f1 cars...
I'm getting a set from a friend who bought them from a guy who had an original 935 and they are used. Its a network thing and they are incredibly difficult to come by.
Maybe Ill build a set when the time comes... maybe with a set of burns merge collectors...
There is no need to use merge collectors with unequal headers like that, they don't need collectors at all. Step-up log design will work just as well and eliminate collectors altogether. If all you want to do is get the gas to the turbo just use a straight pipe and connect the cylinders to it.
I think that is what Porsche did on the newer GT3's.
Stole this pic of a log style system from another post.
At some stage we need to consider these variations are not necessarily done because they are technically superior, instead they are a compromise for the available space.
A rear engine race car of boxer configuration having very little ground clearance running sustained full throttle at high RPM needs to move a lot of gas in very little available space. Look at the size of those primaries. Still, I see one key feature modern high performance engine builders do not violate, equal length primary pipes. |
The Japanese marques and tuners take a different approach to welding in a divider. The best approach is to weld spearate tubes to the two inlets on the divided flange. Thus, the divided section won't degrade. This is the approach I am using for my twin scroll turbo. Again, a true equal length header with divided inlet tracts will typically spool to full boost 500 to 600 RPM sooner than a non twin scroll or twin scroll without optimized exhaust system. Well worth the effort.
Speaking only of well designed short and equal length system for a 930:
An equal length is 'probably' going to make another 20-30hp in the mid to high range than a shorty. A shorty is 'probably' going to come on boost about 100 to 300 or so rpm faster than an equal length. Both will probably come in faster and make more Hp than a stock late 930 HE/header system. The factory stock late 930 headers are probably less prone to failure and have the best ability to deliver heat. There are extreme Porsche Turbo builders that are using shorty's and equal length headers to make up into the 700fwhp and higher range. There are 930 turbo motors running stock late 930 headers making over 500fwhp. (Monster CIS claims over 600hp on stock headers.) Then there is proper sizing of the primary tubes that can reduce lag or support higher HP or turn a well designed system in to a poor performing if not matched to the motor. There is no perfect system for all situations and builds. If we are lucky we have good information to base decisions on and different systems from which to make choices. |
Joining this thread late with great interest but no knowledge of header design beyond what I have read here.
In the discussion of equal lenght, short/long primaries and the like where do the SSI 930 headers fall in design and what is the general consensus on their performance level? I have one of the early prototypes which replaced the stock headers. As the car was rapidly becoming track only the muffler was removed at the same time so I never evaluated the contribution to power/drivability from each individually. The torque especially coming out of corners was very noticeable and rear tire wear became a problem until I settled the right foot down. Interesting thread and thanks. Jim 1980 930 1995 993 |
Jim, I'm gessing Billy built your SSI based header system. He did a few of those and can tell you the specific advantages, the main one being low end torque.
The late 930 headers are basically the same as the Carrera 3.2. Per SW on a Carrera 3.2 w pre muffler and chip at 3500rpm makes about 122hp. SSI w stock muffler and chip makes about 130hp or about 8 more HP at 3500 rpm. At all other rpm they were equals. Per a Bruce Anderson article that had dyno info for different exhaust combo's on a 3.2 Carrera that included comparing a stock header system with a RUF sport muffler against an SSI with 2/2 sport muffler, there was no real difference in hp anywhere except about 3000rpm. At 3k the came in: 98.6 for the stock headers. 102.8 for the SSI's or 4.2 more HP . Thus on a normally aspirated 3.2 motor there was about a 4- 8hp difference between SSI's at stock headers. However, they were equals at all other points except at about 3000-3500rpm where the SSI's had a about a temporary 5% bump in power (savaging?). From here we are just guessing! First, it is debatable if Turbo motors at 3000-3500 would benefit from any savaging. It can benefit from more efficient timing of exhaust pulses. From these two data points I would deduce or guess: Boost onset would not change. The time from boost onset to full boost goal might be shortened with the SSI's. The HP in the early part of the mid range might be increased some. What might be more reliant to shortening time to full boost would be the differences in total volume between the two. I would not guess SSI's have an advantage in this area. What might be more relevant as to which might make the most HP could be tube sizes. I believe the SSI's are 1.5" and the stock headers about 1 5/8's. However, the secondary tubes might change this. The SSI's may be modest by a big 930 turbo standards and the 930 header has the funky cross over and J tube. Call it a tie for now. IMO with what I believe so far, the best thing about SSI's is the quality, heat, and maybe some increase in efficiency early and just past reaching one's boost target where the SSI might be a little more efficient. My guess the SSI with the 1.5" primary tube's might be less than ideal for making HP on a track car but great for a street car. I could very well be wrong but I would not expect a big difference between the SSI and stock late/euro headers if both use a great low restriction muffler. |
The 3.2 is not the right "environment" to draw conclusion on the advantages of equal length design Vs non equal length design at least if you use SSI for the demonstration. This is because SSI are 35mm inside diameter primaries whereas on the Carrera 3.2l Porsche has enlarged the OEM system to 38mm inside diameter primaries. Still the SSI manage to outperform the OEM system in mid range, but are too restrictive at higher revs. If you take an equal length design with the same diameter as OEM on a 3.2 (B&B for example), you will notice an improvement everywhere, and more than 10hp increase at peak power.
On the 930, the OEM headers are still 35mm inside diameter. You will notice an improvement off boost with a "SSI like" system. But on a turbocharged engine, power comes with boost - and nothing beats short headers when building boost is what matters. Still, for a street application, a SSI like design header is very nice on a 930. |
| All times are GMT -8. The time now is 09:01 AM. |
