930 engine
Wondering if anyone can identify what this motor is. 930/60 case, 4/86 dated heads.Doesnt look like a turbo intake though.Was rebuilt and then sat.Value? Thanks guys.
Old 01-09-2010, 04:46 PM
Certified User
billjam's Avatar
930/60 is a 1978-ish 3.3 turbo motor.
The manifolds are 3.2 Carrera.
The original turbo intake parts are in the background.
The silver paint job is making me want to puke.
Bill
1988 Carrera - 3.6 engine (with ITBs, COPs, MS3X) and a whole set of turbo body panels waiting in the attic.
Day job ... www.sspowdercoat.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911
Old 01-09-2010, 05:08 PM
Drive it like u stole it.
jonesb930's Avatar
It also looks like the Throttle body was rotated so that a stock IC could be used. Clewitt does this as he did mine.
____________________________
Bill Jones
Jupiter, FL
77 Euro 911 3.0 Wide Body - under construction
http://www.flickr.com/photos/rennsport/collections/72157618856489537/
Old 01-09-2010, 08:06 PM
copbait73's Avatar
Hope that is silver paint. If not its grit blasting and that is bad news.
Old 01-09-2010, 08:08 PM
7.0:1 > 11.3:1
The tin cylinder baffles, back of the crank, pilot bearing, and various fasteners look to me like they were sitting outside for a long time. Wonder if the ports were covered?
Old 01-09-2010, 11:02 PM
This engine was sitting outside.Had the intake installed but not bolted on.There is cam break in lube on the cams so I guess it has never been run.My guess is there could be water in it or at least moisture. I dont know whether to try and turn it over with a ratchet by hand to see if it spins or leave it alone for someone to dissassemble it and go through.The silver is a spray bomb paint that some jackass sprayed on,not sandblasting which I guess is the lesser of two evils.If anyones interested in this boat anchor let me know.
Old 01-10-2010, 03:43 PM
jonesb930's Avatar
Where is it located?
Bill Jones
Jupiter, FL
Old 01-10-2010, 07:21 PM
very interested in the motor, sent you a pm!
Tom
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud
Old 01-10-2010, 08:02 PM
