turbo and exhaust , what are these worth ?
Hi all, I have a B&B exhaust ..I think that's the correct brand.And I also have a K29 turbo that I would like to sell,but I have no idea what they're worth.I would greatly appreciate everyone's input.I do need to tell you the turbo needs rebuilding because it leaks oil out of the compressor side intermittingly..Not looking to make killing,just whats fair.
Old 01-17-2010, 11:26 AM
No ideas at all ??? I took this stuff off my car about a month ago replaced the turbo with a garrett gt35r,and built my own exhaust,I don't need this stuff anymore..
Old 01-18-2010, 07:35 AM
I'd say 200~300... really, whatever you can get for it...
What about a picture of the one you built?
Old 01-18-2010, 09:23 AM
What can you tell us about the K29 v GT performance?
The K29's are a great turbo for making HP but at the expanse of lag as most are built an a larger hot side.
Old 01-18-2010, 10:39 AM
The k29 comes on later than the gt35, Right now I have a fuel issue,it goes way rich too early so it makes the engine bog down.The afr is in the high 9'S TO low 10'S.I'm sending my wur to BL and I"m getting an rpm switch and solinoid to cure this.When I get this sorted I can be more accurate with my description of the performance differance.I think top end power will be similar,midrange will be improved.
Old 01-18-2010, 03:33 PM
I picked up 34 hp going to the Garrett T35 and more fuel flow capacity set up now has AFR's 11.9-12.1 @ 13.8 PSI steady from 4500 to redline. The dyno results show that maxium boost (13.8 was not acheved until 4200RPM). I suspect this corresonds with the cams grind. I do not know where the K29 boosted from but it seemed to be full at about the same RPM, just started dropping boost over 6000. Now no problems with Garrett. I had oil seals installed in the k29 ( slight seepage on cold side) and installed into another 930 with less internal mods and it holds 1.0 bar boost all the way to redline and seems to pull well from over 3500 as the cams are not as hot of a grind although both are high RPM grinds. Oh, on the original price question, I'd say the muffler could get $300 and the turbo will cost around $150 for seals so $400+ for it if it is otherwise OK. I have some spare stuff so I do not really need it but i can never say no to neat stuff that I will most likely use some day. PM a price once you feel comfortable with a figure.
Anthony @ Voitureltd Bayside WI.
Old 01-19-2010, 02:14 PM
voitureltd,I not sure how to PM...I'm still sort of a caveman when it comes to computer stuff..
Old 01-19-2010, 07:13 PM
I think you just click on my user name and a pm option will appear
Old 01-19-2010, 07:39 PM
Not sure if the pm went thru?
Old 01-21-2010, 10:06 AM
On the turbo reseal I'm just now getting one back from Durobuilt for a similar oil leak problem. I did have one resealed for $150 which is in a car as mentioned in my first responce. However Durobuilt says I got lucky as they should be rebuilt with a complete rebuild kit and fully rebalanced. The price for this is close to $600. So my first guesstimate of what the turbo that needs rebuild might be worth, may be a bit high.
Old 01-21-2010, 12:23 PM
I'd like to sell the stuff make me an offer,I'm not hard to get along with.
Old 01-22-2010, 06:30 AM
Old 01-22-2010, 07:42 AM
pm sent
speednut; I sent you a pm last week with questions about your muffler! guess you havn't figured it out yet. Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 01-22-2010, 11:03 AM
I sent a PM on the 17th and did not hear a reply either.
Jeremy C.
Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham)
----Nothing is far away in this car!----
-1978 911 SC TURBO, Minerva Blue Targa 965 update.
-2008 550i M-Sport
Old 01-22-2010, 12:40 PM
speednut
top right hand cornor of the page where it says private messages. there should be a small triangle if messages were received. click there. I had to ask this question also. Philip
Old 01-22-2010, 01:20 PM
I just sent my K29 to Ultimate Motorwerks and a rebuild is $475.
Bryan O.
77 930
08 Boxster
14 535i M Sport
Old 01-22-2010, 02:53 PM
EmptyGarage's Avatar
WPOZZZ
Have you got any Dyno charts from your 930. Would like to compare to a similar build. There is an "ultimate Dyno" thread here where you could post it.
Thnaks
Old 01-22-2010, 03:08 PM
Originally Posted by EmptyGarage View Post
WPOZZZ
Thnaks
No dyno charts yet. The motor has been out for a year and was ready to go when the turbo seal let loose.
Bryan O.
77 930
08 Boxster
14 535i M Sport
Old 01-22-2010, 08:27 PM
exhaust
Interested if you want to pm me
Old 01-23-2010, 04:55 AM
Heyall , I think I,m getting the hang of this pm stuff.Let me know I'm not doin it right!!!!!!!
Old 01-23-2010, 06:51 AM
