Crotchety Old Bastard
RarlyL8's Avatar
WANTED - useable 3LDZ turbo
I'm looking for a 3LDZ, stock turbo for the 930. Planning to do some comparative dyno testing and need the stock turbo to use as a baseline.
It has to last a weekend without blowing the seals or exploding so blowing a little oil is OK, shaft play is not OK.
Here is your chance to get rid of that 20 lb chunk leftover from the K27 swap.
Thanks!
Old 01-19-2010, 10:30 AM
RarlyL8's Avatar
No one? All those K27 and Garrett conversions? I'll make it worth your while to look.
Thanks -
Old 01-20-2010, 01:13 PM
tj930's Avatar
Brian, I have one. It's perfect (as 3LDZ turbochargers go).
But that's why I'm hanging onto it. (I've kept all the bits of my car, so that I can put it back - should I ever want to sell.) And then there's the shipping costs to send the heavy lump across the Atlantic. (Far cheaper for somebody who lives on the same continent to send one to you, surely?)
Not ignoring you - just kinda hoping somebody else would volunteer!
Old 01-20-2010, 01:27 PM
jayhawk's Avatar
Brian:
I've got one. Looks OK but I have no idea of it's actual condition as it came with the car which already had the K27.
PM me for details
bob
Bob
Past President KCRPCA
PCA National Certified Instructor
1982 930 Track Car "The Pumpkin"
2002 996tt X50 Lapis Blue Street Machine
Old 01-20-2010, 01:29 PM
RarlyL8's Avatar
Thanks guys, I know it's a hassle to box your old crap up and ship, will make it worth the effort. Yes soursing in this hemisphere is preferable, ha!
You have pm Bob.
Old 01-20-2010, 01:54 PM
full quack's Avatar
Send a message via Yahoo to full quack
Hey Brian,
I too have one that is in totally unknown condition. Bought it off Craigs list for $125.00.
No noticeable shaft play (by hand/fingers), spins with a little drag (seals?), but I do not know what amount of drag a perfect working one has???
Tell me what to check, and I will! Then if it will work for you??
Mark
Old 01-20-2010, 02:45 PM
mark '87 930's Avatar
I don't want to part with mine for the sames reasons as tj930 , but i may do it for such a wonderful cause.. not to mention, Brian, you've been helpful with tons of folks on this board including me.
1956 Chevy 3100
2009 Subaru Forester
2003 KX250 X2(I like my toys!!)
Old 01-20-2010, 03:00 PM
Mine made full boost with a 1 bar spring, but smoked coming off boost and I can feel shaft play (no contact though)
Old 01-20-2010, 04:04 PM
RarlyL8's Avatar
Appreciate the offers.
I can't spend too much on this which is why i only want a turbo that can last a weekend without exploding. Shaft play scares me but a little oil blow-by is OK.
Old 01-20-2010, 07:45 PM
full quack's Avatar
Like I said Brian, just tell me what to look for & I'll completely check out the one I have. How easy should it spin by flicking it with my finger? How long should it "free wheel" before seal friction stops it? Etc, etc.
Mark
Old 01-21-2010, 08:00 AM
RarlyL8's Avatar
Mark,
Just grab the shaft on either end and wiggle. Both hot and cold side should have just a tiny amount of movement when no oil is in the housing, no more than a wiggle. When you spin it should be free and not drag anywhere.
I don't want to take your turbo if you are saving the stock parts from your car and that is one of them.
Old 01-21-2010, 10:12 AM
full quack's Avatar
Hello Brian,
The one I'm talking about is a spare I picked up off of Craigs list for $125. That was before I was schooled on how antiquated a 3ldz is.
So now I have a perfectly good working 3ldz on the car, and a spare that I will NEVER use.
I know there is NO play in the shaft, and NOTHING touches or rubs metal to metal at all. Nothing has ever been ingested into it, all bolt holes & studs intact, all flanges in good condition.
I just do not know how much spinning resistance a good working 3ldz should have? I mean I know the seals have to be imparting some "drag" or they could not seal out the oil. So how freely should it spin? I mean if I give it a quick twist with my fingers, how long should it continue to spin before slowing to a stop? 1 revolution? 2 revolutions? More?
Please tell me how it should feel to spin it, and I'll pull it out of the box tonight and check it out for you.
Mailing it to you would not be an issue. I would not want it returned...EVER!
If we agree that it might work for you, I'll mail it to you. Then you try it out first, if it works out for you, then simply pay me back for the shipping & reimburse me the $125 I paid for it.
If it doesn't work for you, then damn, it wouldn't have been much of a backup for me either. But repaying me for the shipping would be a nice gesture.
Mark
Old 01-21-2010, 11:47 AM
mark houghton's Avatar
Originally Posted by full quack View Post
So now I have a perfectly good working 3ldz on the car, and a spare that I will NEVER use.Mark
Mark, you're still running with a stock 3LDZ on your car? I'm shocked and floored - actually, stupified to realize that not everyone has seen the need to upgrade to K27 versions.
I have my stock 3LDZ sitting on the shelf and just the other day pulled it out to check the "wiggle" (something I never did when I removed it years ago). It was working fine and not smoking, but it definitely has wiggle at both ends (not enough to rub the housings), and definitely is in need of a new thrust plate with lots of end-to-end movement. I just happen to have a set of bearings, thrust plate and seals from a K27 with minimal miles (long story)...maybe I'll put them in the 3L to 'freshen' it up if I ever put it back on the car. Ha!
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 01-21-2010, 01:17 PM
RarlyL8's Avatar
Should spin but not for long typically. If it doesn't drag should be OK. I sent you an e-mail.
Old 01-21-2010, 01:56 PM
full quack's Avatar
Hey Mark,
It's not for the lack of wanting, it's more tha fact that I don't have $ to do it all & to do it right. You know...new turbo, new full bay intercooler, new headers. Believe me, I will do just that, just as soon as my house is paid off!
Mark
Old 01-21-2010, 02:50 PM
Hey Mark,
Mark
Damn mortgages....always getting in the way of what's truly important and sacred.
I'm almost done spending money on THIS car, so I can double up on the house payment and maybe have it all gone in time to retire. House paid, high performance Porsche to assure my wife an early life insurance payout....such a deal.
Old 01-21-2010, 04:38 PM
Drive it like u stole it.
jonesb930's Avatar
Brian,
If mine checks out it will only cost you shipping. I will be needing a set of headers so we can work something out. I am heading out to the garage to measure the shaft play.
Bill
____________________________
Bill Jones
Jupiter, FL
77 Euro 911 3.0 Wide Body - under construction
http://www.flickr.com/photos/rennsport/collections/72157618856489537/
Old 01-21-2010, 04:52 PM
RarlyL8's Avatar
That'll work Bill. The dyno work I am planning includes the new headers.
Old 01-21-2010, 05:15 PM
jonesb930's Avatar
Brian,
I took the compressor side housing off to inspect the internals for any contact and to get a good measurment of the shaft side play. I used my dial indicator and setup to measure.
Side play was .015" of an inch
End play was .004" of an inch
The inside of the compressor has no signs of contact and the compressor wheel looks good. It obviously needs a good cleaning though. The shaft spins free but does not free wheel so the seals appear to be ok. Hard to tell without putting oil pressure to it though. This turbo was changed after finding some oil residue in my intake plenum. I never had the issues of blue smoke after lifting off the gas though. Is there anything else I should check?
Bill
Bill Jones
Jupiter, FL
Old 01-21-2010, 05:24 PM
jonesb930's Avatar
One more thing, the exhaust side had one broken stud (beneath the housing) and two missing studs on the outlet.
Bill
Bill Jones
Jupiter, FL
Old 01-21-2010, 05:27 PM
