LinkBack | Thread Tools | Rate Thread |
Is this hose magical...$$$
sudo apt-get purge 930
I had the same sticker shock when I was going to replace mine. I cut the metal band holding the hose and replaced with standard hose and a clamp.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Any idea why its priced so high??? I am used to Porsche mark-ups
Most local hydraulic supply shops will replace with the proper hi pressure hose and crimp for just a few bucks.
Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. |
To answer your question: Yes, it's magical.
Sorry, but it would be against my principles to pay three hundred bucks for a stinkin' foot of rubber hose! Get real, screw OEM in this instance. Am I wrong, but isn't that only a breather hose, after all? Get yourself a piece of heavy walled heater hose (or something similar) from your local Smucks or NAPA and let the purists slam your ride for not being concours...while you laugh all the way to the bank. Use the $300 you saved toward your next go-fast modification. Chances are good that rubber hose technology has improved over the last 20+ years, outshining the more pricey German made.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification. Last edited by mark houghton; 01-21-2010 at 12:59 PM.. |
Your best bet is to get silicon hose from the parts store. I believe it was 7/8th inch hose. Ididnt plan ahead and used some hose from Tractor supply
On a side note, I did call up porsche to see if they had the hose in stock. They didn't, but said it was in the 60-70 dollar area my cost. Thats just an fyi. My car is a 76 2.7, and I believe we are talking about the breather hose from back of the case to the oil tank. I would "assume" your hose would be similar in construction and price, although part number would be different. I say that because the parts guy said the hoses are "different" from year to year, whatever that means.
Thread Tools | |
Rate This Thread | |
