Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
klefroid's Avatar
Turbo boost question 930 3.3
hello,
my boost indicator dusn show me anything. what are the possible causes?
Where can i find the turbo pressure sensor? ( not the overboost sensor)
Thanks a lot. srry for the bad spell
Kurt
Belgium
Old 01-29-2010, 12:49 AM
tj930's Avatar
It'll either be
1) The Boost Sensor (~$100)
2) The Boost Gauge (~$200)
or
3) The wire connecting the Boost sensor to the Boost Gauge! (Many hours of labour)
Given the age of the car (and unless you've had the engine out recently), it is most like to be the Boost Sensor.
Unfortunately, I don't have a picture but you'll probably have to take your Intercooler off to get at it. But Mark Houghton has been experimenting (with a saw and cut his 'Re-circulatory valve' in half), and the boost sensor is the bigger, red one in this picture.
The hole to the right of the picture is where the Intercooler is attached.
Old 01-29-2010, 01:27 AM
klefroid's Avatar
Originally Posted by tj930 View Post
It'll either be
or
Thank you, this was answer where i was looking for!
Verry usefull. Respect
Old 01-29-2010, 02:33 AM
mark houghton's Avatar
You can't miss seeing that sensor, it pretty much stares you right in the face almost dead center when looking at the engine, just below the intercooler.
Also, you might find this thread worth reading...especially to troubleshoot the sensor itself.
boost sensor resistance data
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 01-29-2010, 07:21 AM
