Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
VZ935's Avatar
Send a message via AIM to VZ935
Originally Posted by kenikh View Post
That's why I'm going water air
Sent from my Nexus 6P using Tapatalk
We did on my buddies race car. The two water intercoolers were about 500 bucks
A bunch of old race cars
Old 07-21-2017, 10:01 AM
VZ935's Avatar
Originally Posted by jwasbury View Post
that's a fine looking Ladeluftkuehler.
and RIP JBL930...first thing that came to mind reading this old thread is that Jonathan is no longer with us.
Sorry to hear. Hope he is in a place were Secan IC's and all kinds of goodies are just laying on the shelf and ready to bolt on.
Old 07-21-2017, 10:03 AM
Brando
quattrorunner's Avatar
Originally Posted by vz935 View Post
the last used one that i know of selling went for 17,500. New 25,000
yen!?
Turbo powa!
1977 911s. it's cool
Old 07-21-2017, 11:07 AM
Alan L's Avatar
I spray water over my IC. I pulled the temps down from 53 Deg C to 44 deg C - back to back comparison at around 15 deg ambient. Stock IC.
Switching to a 964 IC and same comparison at around same ambient, pulled temps down to 29 deg C.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 07-21-2017, 09:42 PM
VZ935's Avatar
Alan
Exactly what I used did on one of my cars and it works. The Motes ECU would control the function based on temp
Old 07-22-2017, 07:24 AM
Alan L's Avatar
When I get really serious I stuff ice into the water reservoir (the windscreen washer bottle). I have a couple of fine mist spray nozzles L and R of the IC - located in the lid. They spray a fan across the IC and the engine fan sucks it thru.
Regards
Alan
Old 07-22-2017, 11:21 AM
50/50 alcohol and water for a bigger drop
Old 07-22-2017, 01:08 PM
Alan L's Avatar
Yes. but would you be concerned about spraying alcohol over a hot engine? I have no concerns about the water - but what happens when the alcohol evaporates from the water on a hot engine?
Probably too small an amount to worry about - but it did concern me.
Alan
Old 07-22-2017, 01:37 PM
You would have to pump a LOT of alcohol to get to a flammable concentration. The LEL (lower explosive limit) of methanol in air is 6.7% by volume. The 3.2 fan does about 600 L/sec of air at 3000 crank rpm I think, only increases from there. So to get to 6.7% LEL you have to pump about 40 L/sec. of methanol. Methanol has the lowest boiling point but the bad part is you can't drink it.
Old 07-22-2017, 02:43 PM
Alan L's Avatar
Hmm. Food for thought. I wanted to do water/meth injection but the fun police that make the rules said prohibited.
If I do catch fire - will you come and help put it out :-)
Regards
Alan
Old 07-22-2017, 03:06 PM
Only if you buy the ticket
Old 07-22-2017, 05:47 PM
Looks like a custom bellhousing setup that secures the transaxle to the tub in an add'l spot so the engine can just be pulled out the back, very cool. Any add'l info? I also see no boots on the CV's just grease them a little before each race?
Old 07-23-2017, 06:52 AM
VZ935's Avatar
That is an Emco sequential box
Old 07-23-2017, 07:12 AM
3 restos WIP = psycho
kenikh's Avatar
996 body work?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-23-2017, 07:15 AM
VZ935's Avatar
996 body work?
Yes
Started life as one of Bucklers early 911 race cars
The story of how that car came to be is funny. It all started with my 935-84 and the 935-84 spare chassis.
Old 07-23-2017, 08:33 AM
It looks like the engine hanger does double duty as a rear cross member between the longitudinals. I'm looking at doing this on a street car so I can cut out the rear cross member part of the tub between the longitudinals so I can free up space for rear mounted twin turbos up high then have space below for mufflers, I do not want to run side mounted turbos.
Old 07-23-2017, 08:54 AM
VZ935's Avatar
I have been thinking about making a kit for this based on whet I have on the Kremer K3
Old 07-23-2017, 09:41 AM
Alan L's Avatar
Man, you got some uber cool s..t.
Alan
Old 07-23-2017, 11:23 AM
Metal Guru
911nut's Avatar
I've been out of the loop.
What happened?
Paul B.
'91 964 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, - 210 lb
Old 07-27-2017, 11:13 AM
jsveb's Avatar
What happened?
Very sad story. If my memory serves me right, he was killed in a fight.
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 07-27-2017, 09:02 PM
