Blitz Boost Controller
Is anyone familiar with the Blitz dual solenoid ebc? I just had it installed in my car and have a few questions:
* what gain & ratio setup do you use?
* the ebc shows peak boost to be 0.71 bar (0.7 bar spring in Tial WG w. B&B headers & muffler), but the boost gauge (inyourfacegauges) shows 1.04 bar peak. Which one shows the correct boost?
Cheers.
(I posted the same thread on RL.)
Old 01-30-2010, 08:22 PM
2 basic questions
1. are you sourcing the boost signal at the same place?
2. what is the sample rate of the ebc and the gauge
I'm looking to install an ebc and interested in what you find. It is hard do find usable info
with all the rice web that is out there.
Old 01-31-2010, 08:14 AM
boost signal source after T/B on intake manifold?
Old 01-31-2010, 08:15 AM
930gt-40r's Avatar
May want to relocate that to the cold side of the intercooler before the t/b- the blitz may not like to ever see vaccuum for where it picks up the boost reference.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 01-31-2010, 08:20 AM
I will have to find out from the mechanic where the boost signal is coming from.
Old 01-31-2010, 09:42 AM
the boost is sourced at the same location for both the EBC and the boost gauge. The boost is sourced from the hose that goes from the IC to the wastegate. I don't understand how they can both read different boost levels. Furthermore, the spring in the WG is a 0.6 bar spring (instead of 0.6 bar as stated above), but the EBC reads 0.71 and the boost gauge 1.04 bar!!!
I am having the garage attach a manual gauge to determine what the actual boost level is. Something doesn't add up...
Old 02-01-2010, 05:33 PM
Boost spikes when the T/B snaps shut
I moved my boost gauge signal to after the T/B and I have logging
Not having logging is a real issue with the boost gauge you have
how vacuum affects the Biltz i can not answer BUT the blitz was the one I was considering
Old 02-01-2010, 07:13 PM
PLX has logging capability, however I am waiting for them to release the device that allows me to log along with RPM.
What is T/B?
Old 02-01-2010, 07:22 PM
Infidel
JBL930's Avatar
Throttle body?
Jonathan.
87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines.....
Old 540 BMW, XB12S Modified, for being a total hooligan
Old 02-01-2010, 07:48 PM
Originally Posted by JBL930 View Post
Throttle body?
Cheers.
Old 02-01-2010, 07:52 PM
