It started off as good day, but.......
Well laid plans always go wrong.
This weekend was going to be productive, and a perfect time to tear out the original suspension and remaining A/C components. Clean and prep for my new coilover suspension and Smart ARB's. And do a little surface rust repair, or so I thought.
It seems a past battery leaked enough to go through the pan and into the built-up crossmember between the front suspension points, then rust out the bottom of the crossmember.
At least I got that pesky Mouse with my carefully planned trap!
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 02-07-2010, 02:17 PM
A930Rocket's Avatar
I hate when stuff like that happens. What's the game plan? Can you fix the damage yourself or need to farm it out? Good luck!
Old 02-07-2010, 02:29 PM
It'll be a DIY job.
I built a wide body RSR look out of a rusty 72T about 20 years ago, and that was a job. This won't be as bad as that project, but with work getting in the way, this may take awhile.
I found a good write-up on R-list.
1986 911 Turbo
Old 02-07-2010, 03:07 PM
Finally got some garage time.
Quite a bit of rust in the left longitudinal, so I bought a new one to piece in. For pan alignment purposes I left it in for now. Once the pan is tacked in, I'll cut and splice in the new longitudinal. I'll also have to fab a little metal for the left front corner of the pan next to the bulkhead.
1986 911 Turbo
Old 03-28-2010, 12:52 PM
A930Rocket's Avatar
Looks good! I wish I has the talent to do that kind of work. Keep us posted.
Old 03-28-2010, 05:09 PM
I just have the stupidity to do this work.
1986 911 Turbo
Old 03-28-2010, 05:26 PM
Wo ist die Rennstrecke?
DonE's Avatar
Love to see real DIY work. Good job and good luck.
Old 03-28-2010, 06:01 PM
This is just a minor bump in the road, compared to all the DIY work you've done on your car!
1986 911 Turbo
Old 03-29-2010, 12:43 PM
