Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
R.I.P.
drmatera's Avatar
We have plans for my intercooler. Our design will be based on air flow path and distribution across the cores. We will have diverters welded inside the tanks to ensure the whole core gets even distribution of air to maximize cooling. Cast tanks would be great but weight and cost prohibit that
Old 02-09-2010, 12:04 PM
The 964T is my favorit. Not only dose it have a wide thin core it has the best end tanks.
Further the goodness starts at the turbo discharge with a tube that is steeped on the inside to provide smooth flow and transition from the turbo and into the IC.
RUF chose it for most its C2 & 993 conversion kits and I think for up to a rating of 425hp. However, they added a flange around it to aid in sealing.
Old 02-09-2010, 01:04 PM
Metal Guru
911nut's Avatar
Originally Posted by copbait73 View Post
Not to disparage any of the aftermarket coolers shown however look at the location, angle and attention to detailed "flowing" of the stock 964T intercooler inlet casting. I would think that given many years to test numerous configurations leading up to release of the only improved CAC on the single turbo motor this may be a design configuration to duplicate for maximum efficiency.
Don't think so.
Stock intercoolers are built to a price point that's lower than the aftermarket. They are good at what they do, give what they are but they aren't the last word in efficiency.
After you read this you might change your mind: 9M Prototype intercooler test report - Rennlist Discussion Forums
Paul B.
'91 964 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, - 210 lb
Old 02-09-2010, 01:46 PM
copbait73's Avatar
Originally Posted by 911nut View Post
Don't think so.
Don't confuse my comment regarding efficient handling of airflow with the cost and performance of the basic heat exchanger core. No OEM can justify the cost of a premium core configuration. Premium cores are not cost/benefit justified for most street applications. Only those who track their cars or those running at extreme HP are getting payback on their investment over what the OE provides from the factory.
Old 02-09-2010, 02:08 PM
I think that is the same thread I once read on the 9m. If so my take away was it was hard for most the aftermarket I/C's to beat the stock 993TT intercooler and many had spend a lot of dollars on IC's thinking they would make in improvement only to discover from some of the tests that was not to case.
There seems to be very little quality testing of intercoolers. I would guess any testing would include the temp deltas as well as pressure drop.
I like these end tanks and IC for a fabricated unit. Note the ducting to the motor intake.
Old 02-09-2010, 04:16 PM
Wo ist die Rennstrecke?
DonE's Avatar
Thought I would throw my Bell IC out here too. Thanks to David (125shifter) for his specs as it works very well. If I had it to do all over again, I would make it side to side and 3in core but again, it works well for my EFI conversion.
I thought I would throw this one in to show how I use the stock 3.2L throttle position. No need for cutting and twisting.
Old 02-09-2010, 05:29 PM
I don't think Ruf used the 964 on any application but the RCT.
Lincoln Phillip
87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound.
Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs.
"the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker
Old 02-09-2010, 05:34 PM
C2 & 993 RCT at apx 380hp and Evo at 425hp if I recall correctly but it has been years.
Old 02-09-2010, 07:37 PM
Blackbird Pilot
Reaper930's Avatar
The hoses are feeding the turbos...
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us
Old 02-10-2010, 02:12 AM
Garrison's Avatar
Done, you said above side to side and 3 in core... I am assuming you are talking about the tanks being on the sides, or the rows running side to side vs. top to bottom? Just wondering what you ment and why? Trying to make sure I get it right when I order this. THX
1996 Porsche 911
2013 BMW 335xi - Wifes car
2007 4Runner - 4x4 for Colorado snow
Past: 1988 Venetian Blue 911 Targa, 1983 Black 930, 1984 Black 911 Coupe
Old 02-10-2010, 06:07 AM
Don, I to am wondering about your comment.
In my words your current core runs front to back. If you are saying a 3" side to side, I would not think you could get enough CFM through it.
Your current fabricated IC is a great set up I would think assuming the core size is fit to your HP.
I could see keeping your current lay out and going to a 3" core if it flows enough CFM to support your current HP level.
Old 02-10-2010, 06:33 AM
RUF C2 RCT w C2T intercooler.
Old 02-10-2010, 08:40 AM
copbait73's Avatar
Nice picture, it shows the "flowing" on the inlet much better.
Old 02-10-2010, 08:44 AM
1988 M491
Corky does great work.
Old 02-10-2010, 11:22 AM
I've been debating the same thing on my EFI setup. All the books show flow in the short direction, but is this optimum for a 930? High HP guys like Juan and Bello run side-to-side. Looks like you could get very nice intake air flow from the turbo, thru the IC and back to a Carrera intake with a side-to-side.
If we look at the cooling air through the IC, we may be missing an opportunity to get maximum cooling by a front-to-back IC, where the intake tank is located may be in the best cooling area of the engine and tail. An IC is only as good as the cooling air through it. When you look at the tail closed, you see a pretty big gap between the IC and the opening, towards the rear edge of the tail. This area is also located over the biggest open void in the engine compartment, that dumps straight into the engine fan, and would seem to offer the best flow through the IC.
Seems like the best airflow through the tail grille into the engine is the back half of the grill, and maybe the best place for the IC, which probably means a side-to-side.
This is all pure speculation, of course.
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3 w/MS3X, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 02-10-2010, 11:56 AM
R.I.P.
drmatera's Avatar
If you took advantage of that rear area how would you close the lid?
Old 02-10-2010, 12:23 PM
You couldn't get all the way to the back edge of the grill, but could get pretty close with my measurements.
A perfect solution would be the DP extended tail.
1986 911 Turbo
Old 02-10-2010, 12:26 PM
R.I.P.
drmatera's Avatar
yes, I had a DP on my '79. It allowed for a huge intercooler. Maybe if we remove the hood hinges and make it pin on, then you could hook it around the monster cooler and juggle it into place.
Old 02-10-2010, 12:50 PM
David's Avatar
I don't see how you can flow enough through the side to side's to make the HP, but obviously Juan and Bello are doing it so I guess my math is off.
It really seems like it doesn't matter. Side to side, the air travels farther in the IC but the velocity is higher. Back to front, it doesn't go far but the velocity is low. It seems like the intake air spends about the same amount of time in either configuration.
Maybe someone who's spent too much time figuring on this can chime in
2014 Cayman S
2011 Cayenne Turbo
Old 02-10-2010, 03:42 PM
copbait73's Avatar
For starters, the most efficient charge air cooler (CAC) has the most temperature drop while impacting pressure the least amount.
Side to side generally works best overall because at some distance past the entrance to the core most of the heat is removed and there is very little to be gained by traveling any further but something to be lost, pressure. This desired distance varies of course by how much heat is present in the gases at the entrance to the core.
Long(er) distance is needed if you have a killer HP turbo motor because the high boost introduces higher starting temperatures to the core, therefore a longer passage is needed to get the cooling accomplished.
My only comment regarding the two high HP subjects is that they are more properly sized for their intended use vs. many of the aftermarket CAC which frankly are oversized for the light duty most are exposed to pulling stoplight racer duty. But hey, if it wasn’t for the imposing size, how many guys would pay up to $2000 for something that only gives 20-30HP.
Old 02-10-2010, 04:34 PM
