Garrison's Avatar
Bell Intercooler
I have been talking with Bell Intercooler about having them spec up one for me, and have a couple questions for you guys.
For mostly street driving, with some track work, what would make the most sense; half-bay or full-bay? Or does it really matter? I have read and heard that the larger the intercooler the potential for longer spool up.
I am still learning when it comes to these cars, and am not sure what would be best for me. I don't plan on anything crazy... headers, K27S, 1 bar spring (once larger cooler is in place), no A/C, etc.
Also, has anyone had any experience with Bell? They seem to be top notch on the phone and over e-mail. Can build me a half-bay in 1 week... full-bay in 2 weeks. Cost is basically the same... roughly $1000.
Thanks guys!!! Here are a few pics for you.
1996 Porsche 911
2013 BMW 335xi - Wifes car
2007 4Runner - 4x4 for Colorado snow
Past: 1988 Venetian Blue 911 Targa, 1983 Black 930, 1984 Black 911 Coupe
Old 02-08-2010, 07:58 AM
David's Avatar
That top engine is mine and it's a Bell core but I fab'd up the tanks at work.
I asked Bell about the lag from the larger intercooler and they said you might notice the difference if you drove two identical cars with different intercoolers, but otherwise it's insignificant.
The only drawback to the Bell cores is the weight. My intercooler weighs right at 30 lbs.
If I did a full bay again, I'd probably use a 3" core to lose some weight. Unless you really want the AC condensor in the back, I'd go full bay so it's as efficient as possible.
2014 Cayman S
2011 Cayenne Turbo
Old 02-08-2010, 09:09 AM
Garrison's Avatar
Yeah, they recommended a 3" core due to my HP goals, and for weight savings.
1996 Porsche 911
Old 02-08-2010, 09:27 AM
Crotchety Old Bastard
RarlyL8's Avatar
I am working with Bell on development of the stock replacement unit in the second picture. It will look more refined when finished and there will be zero fitment issues, a true bolt-on.
Old 02-08-2010, 09:40 AM
wjfk32's Avatar
What about a Kokeln style intercooler??? Larger surface area..etc.etc...
The 2nd pic doesn't look that thick/camera angle or does that matter.... Questions
Walter
Old 02-08-2010, 10:06 AM
Forced Induction Junkie
WERK I's Avatar
David,
Do they do full bays with a thinner core?
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 02-08-2010, 10:10 AM
Garrison's Avatar
They do full bays at thinner cores for sure. I am looking at 3" vs. 4.5" as David has. For the cost it sure seems like it is hard to beat...
Brian, you are working with Bell for your car, or for another product line? Just wondering... seems like they could be a good resource.
1996 Porsche 911
Old 02-08-2010, 10:16 AM
I worked with Gerhard @ Bell to design mine as well. Mine is based on a 4.5" full bay core, but different than David's though (There's a picture of mine in the Turbocharging Performance Handbook ) - Gerhard suggested a left-right core as opposed to front-back.
I am very happy with the performance though weight is the big penalty. I remember weighing mine & its close to 40lb.
I suspect if you only use your car for street, a thinner core would suffice.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 02-08-2010, 10:47 AM
125shifter,
That setup looks great. I am interested in doing an almost identical intercooler setup except I will probably go with a 2.5-3" IC.
Can you tell me a little more about the plumbing? It looks like you drilled a new opening in the engine tin for the air cleaner to the turbo inlet.
Can I ask where you sourced the pipe and other fittings?
I assume your BOV is behind and attached to the IC.
Old 02-08-2010, 11:00 AM
David's Avatar
Originally Posted by forwheeler View Post
125shifter,
The inlet pipe is 3" (I think) so I had to open the tin a little. I also had to dent it a little to clear the engine mount. 3-1/4" or more would be better, but I wanted to keep it in the stock location.
All the tubing is from Burns Stainless - Home
If you look close, you can see the BOV on the turbo to IC pipe, where the distributor would normally be.
2014 Cayman S
2011 Cayenne Turbo
Old 02-08-2010, 11:38 AM
Cool, thanks for the info! I may be calling Bell soon.
Old 02-08-2010, 11:55 AM
R.I.P.
drmatera's Avatar
i've got 2 bell 12"x8"x3" cores that i plan on making my intercooler with when i do the twins. considered laying them out like a stock 993TT with the inlets to the outside blowing into a common plenum then to the TB. With a difuser in there to direct flow
Old 02-08-2010, 08:04 PM
Blackbird Pilot
Reaper930's Avatar
I had a new Bell fabbed up for my K3 in the rear seat, 3" thick , 10 x 30"...cooling is about the thickness with these cars, or lack there of. The thinner the core (min 3") is better with wider bay design for more airflow to surface area ratio as the air in the thicker cores heats up quick, so unless you're feeding it tons of air, thicker isn't always better.
My IC is force fed via ducts in the rear quarters and I didn't even go with anything thicker than 3".
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us
Old 02-09-2010, 01:30 AM
Wer bremst verliert
JohnJL's Avatar
I use a bell, very happy with Gerhard, Corky and their advice and workmanship
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 02-09-2010, 03:47 AM
Drive it like u stole it.
jonesb930's Avatar
Bell has a great selection of core sizes as well. I am leaning towards them as well. I don't plan on buying until I get everything else mounted up and the engine back in the car so i can maximize the size and keep the fitment clean.
____________________________
Bill Jones
Jupiter, FL
77 Euro 911 3.0 Wide Body - under construction
http://www.flickr.com/photos/rennsport/collections/72157618856489537/
Old 02-09-2010, 05:54 AM
Garrison's Avatar
Good to hear that so many people on here are either using them, or looking to use them. Guess I know what my next mod will be.
1996 Porsche 911
Old 02-09-2010, 07:47 AM
CIS or EFI?
Air Conditioning or not?
Have you done a search using "intercooler"? lots of very good info to be had.
The core, end tanks, and air ducting through the IC all are important to good intercooler performance.
A thinner wider core it better. A thick core needs a longer run to work as well.
The more air through the core the better the IC is going to work.
Note that 993TT not only has ducting for the intercooler but also ducts the motors intake up to the grill surface to ensure it gets fresh air. If we allow the intercooler to preheat the intake air it would go against all our goals.
Poor end tank design can add to pressure drop and turbo lag.
Of course extra volume has to be pressurized and that takes time.
Maybe more importantly might be to consider how air flows through the IC. Quick changes in direction & volume creates turbulence and contributes to back pressure. Abrupt corners that usually come with most fabricated tanks can also create turbulence and add to the pressure drop expected from the core. A well designed cast or CNC'd end tank like Porsche or MODE uses is usually going to make for a more orderly air flow and be best.
Notables from other threads:
Originally Posted by 964 T #304 View Post
You could also use a C2 turbo type system that has a shroud on intercooler and also vents dedicated for air to air box and engine.
Old 02-09-2010, 09:27 AM
Garrison's Avatar
This is of interest for sure. I was wondering if anyone that goes with a full-bay has issues with airflow to the intake as well? Was the above home made, or is this a kit?
1996 Porsche 911
Old 02-09-2010, 09:41 AM
He made it himself.
Great idea.
Old 02-09-2010, 10:02 AM
copbait73's Avatar
Not to disparage any of the aftermarket coolers shown however look at the location, angle and attention to detailed "flowing" of the stock 964T intercooler inlet casting. I would think that given many years to test numerous configurations leading up to release of the only improved CAC on the single turbo motor this may be a design configuration to duplicate for maximum efficiency.
Old 02-09-2010, 12:19 PM
