Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
JWest Headlight relay kit
I bought one of the JWest Headlight relay kits for my 77 Turbo. The instructions seem to be a little different regarding the 2 connections at the fuse panel. The instructions say to use the wires from 5 & 6, but looking at the wiring diagram, it appears that it should be, I believe, 3 & 4 from the fuse panel toward the from of the car.
Has anyone installed this kits before?
Thanks.
Karsten
1977 Turbo Carrera - Work in progress
1971 911E Targa - Almost gone
Old 02-08-2010, 12:44 PM
stevie 77 930's Avatar
you might want to see this post from a few years back....
New Headlight Relay Kit available from Pelican
2018 GTS
2017 BMW 340I M Sport Package
1977 930 (recently sold)
1976 911S , 1973 1/2 911T, 1972 911E (long gone)
Old 02-09-2010, 09:29 AM
Thanks for the link. Great information.
Have you installed the kit in your '77?
Karsten
Old 02-09-2010, 02:19 PM
Karsten,
Yes, I installed the relays on my 77 930, and yes the fuses were different than the instructions provided. I recomend a 12 volt test light and use the owners manual to help identify the correct fuses for low and high beams. Once you determine which ones, follow the directions provided.
2018 GTS
Old 02-09-2010, 08:51 PM
Steve,
I used a test light, and read the inside of the fuse panel cover, and the left and right headlights appear to have different fuses for each the low and high beam. Which ones would I use to connect for the relays? There are two yellows and two whites, one of each gets connected to the fuse panel, and the other gets connected to the wire that was in the fuse panel. That leaves two wires in the fuse panel for the headlights that are not running though the relays. Or are only the high beams run through the relays?
Karsten
Karsten
Old 02-15-2010, 04:52 PM
Karsten,
You run each circut thru each of the relays, one for low beam and the other for high beam.
I ll check the fuse #'s tonight and will post later.
2018 GTS
Old 02-17-2010, 06:29 AM
Karsten,
I have tagged the fuse #'s in the picture. Its a little difficult to see, but going from left to right you have High Beam Fuse #1, High Beam Fuse #2, Low Beam Fuse #3 and Low Beam Fuse #4. The #'s refer to the fuse numbers as indicated on the fuse panel cover. The instructions provided in the kit, count the fuses down starting from the front of the fuse panel. It makes it a little confusing at first......You may also see how the relays are wired into the fuse block.
I hope this helps
2018 GTS
Old 02-17-2010, 06:45 PM
