e p slick's Avatar
Limited Slip identification question
Na
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 02-18-2010, 04:54 PM
Banned
Here you go: Lsd?
Old 02-18-2010, 05:05 PM
Infidel
JBL930's Avatar
I have never personally worked on transaxles so pose this elementary question. How, without disassembling my transaxle, do I know for sure that I do or do not have an LSD? The trans is out of the car. I believe all 930 trans had LSD so I imagine mine does. Feels like it has clutches however. When I rotate one CV hub forward I can feel resistance on the other hub. I can rotate both hubs in the same direction at the same time. Opinions please?
Thanks EPS the Simple
Very simple test, and by the way LSD was an option on 4 speed boxes! If you turn one shaft and the other turns the SAME way it has LSD, if it turns the opposite way it's a normal diff
Jonathan.
87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines.....
Old 540 BMW, XB12S Modified, for being a total hooligan
Old 02-18-2010, 05:07 PM
and it was option number 220.
if it's origonal to the car and the sticker is still on the underside of the front hood, 220 will be on the list of options.
Old 02-18-2010, 05:33 PM
I've heard that a Quaife ATB differential acts like an open differential with the wheel test stated here. So it may have a Quaife in there.
Old 02-18-2010, 06:15 PM
Stand on it in first gear on a slight bend, if you catch a glimpse of your own taillights you have an LSD!
Any luck selling your car?
1987 GP White 930
1977 Ford Bronco
Old 02-18-2010, 06:59 PM
