Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Me like track days
Craig 930 RS's Avatar
Question ELECTRICS - what happened?
Driving along, Porsche 930 with twin plug MSD ignition .... and sputter, miss....voltmeter reads under 8 volts.
Gets worse, more missing as if spark occurs only every 3 or so firing chances.
New battery added today and fires and runs - (former battery was 6 yrs old anyway so got a new Odyssey as a matter of course)
Alternator 100%? Was the battery providing all the energy and the alternator doing zip?
Not certain, haven't had an alternator go out on a car in years!
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 02-20-2010, 10:20 AM
Metal Guru
911nut's Avatar
Batteries get more resistive as they age. If that's the case, the alternator wouldn't be able to charge it no matter what.
Paul B.
'91 964 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, - 210 lb
Old 02-20-2010, 10:42 AM
7.0:1 > 11.3:1
Was the 8 volt measurement taken with the engine turned off? or measured with the engine running?
Old 02-20-2010, 11:42 AM
Me like track days
Engine running: I hooked up the new battery and the voltage while engine running is a tad over13v.
I'll need to measure while running at 2000 rpm
Does a voltmeter dash gauge measure voltage coming from the alternator or battery?
Old 02-20-2010, 12:58 PM
7.0:1 > 11.3:1
Some what the higher of the two. Look at the voltage with engine off (battery) and compare to when it's running (alternator). The output from the alternator exceeds battery voltage, about 14.8 or more iirc. This simple test will not deterine if the alternator is capable of full output load but it will quickly display if your alternator is kaput.
Old 02-20-2010, 01:16 PM
930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
Depends where your tapped in at, if you want to get technical,but the alternator provides voltage throught the whole car. Just dont tap into regulated voltage, a good source for reading alt voltage is like a cigarette lighter circuit,something that doesnt get used that often,well Im not a smoker though.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 02-20-2010, 01:27 PM
Ken911's Avatar
my voltage regulator on my alternator crapped out a couple months back the alternator was only a year old. measure the voltage with it running should be around 14 then turn on the lights and the ac. see if it drops to 12 volts or so, if it does your voltage regulator is going. I pulled my alternator out was going to spend the several hundred for another one. but no one had one in stock so on a whim i took it to a alternator repair shop. He tested it and said nothing was wrong with it and wouldnt charge me anything. I was only having the problem when the engine was heated up good. when i told him that he said the voltage regulator might be going and failing when hot which he couldnt duplicate. So i bought a genuine porsche voltage regulator and the problem went away. The old one looked a little burned when i took it apart.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
05 Cayenne S lapis blue
Old 02-20-2010, 04:00 PM
Me like track days
Results across battery:
Measured with nce quality VM; 13.3 volts with car off, 13.7 volts with car at 2,000 rpm.
Drive it to see what the gauge voltage does?
Old 02-28-2010, 01:43 PM
Me like track days
Well, crap.
Went for a 45 min drive and 30 min into it the voltage started dropping...from 12.5 BAM down to 10....then a big drop to 8 and engine cutting out...
Old 03-07-2010, 09:07 AM
h20cooled7's Avatar
sounds like you are running off the battery, car will run off the battery till you deplete the voltage to keep the engine running.possible alternator or regulator, make sure all main grounds are good also, trans to chassis and battery ground to chassis.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 03-07-2010, 10:23 AM
