Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
930porsche
930 porsche's Avatar
RPM drop
Mark, I will go over it and get back with you. Thank you to all of you and your inputs. I will get back to you with hopefully good news.
Old 02-23-2010, 01:09 PM
Crotchety Old Bastard
RarlyL8's Avatar
Jean,
I would not adjust anything until you check your pressures. If your pressures are off AND you have fiddled with other things you now have multiple problems.
If your WUR is not getting power or is faulty in any way it will show up in the pressure curve. I'll post a picture for you this evening.
Old 02-23-2010, 02:01 PM
Infidel
JBL930's Avatar
Saved you a job Brian
Jonathan.
87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines.....
Old 540 BMW, XB12S Modified, for being a total hooligan
Old 02-23-2010, 02:14 PM
I would also stick a timing light on it and check the timing because if the timing is retarded to less than stock for some reason you'll have a slow cold idle that will die out and stall when the cold start vacuum retard solenoid opens after a minute or 2.
That is if there is a cold start vacuum retard solenoid on your car.
The timing specs for your car should be on the inside of the rear lid. you have to duck down and look up at it while it's open.
The owners manual has the correct timing specs too, if it is the origonal manual that came with your car.
Old 02-23-2010, 02:15 PM
RarlyL8's Avatar
This is how/where you mount the pressure gage. The gage plumbs between the left hand (14M) fitting on the WUR and the fuel head. You can check your system pressure as well to see how the pumps and head are doing.
Old 02-23-2010, 06:43 PM
930porsche
RPM drop
Ok Brian I am going to buy a fuel guage today. I was wandering if I could use a 1986-1989 WUR? It should be the same one on a 3.3 engine. Let's get a step further. Can any of the air cooled turbo interchange their WUR? To me it looks like they should. Anybody has any good feedback about it or confirmation?
Old 02-24-2010, 09:07 AM
930porsche
RPM drop
No air leak or fuel pressure drop on top of engine. after a good warm up the Idle screw turned all the way into the close clockwise position will not shut the engine but keep it running at about 1050 RPM. When accelerating, the engine stop and then idles ok then dies off later on. I think it is under the car. Maybe air leak somewhere underneath. Any suggestion?
Old 03-15-2010, 11:41 AM
mark houghton's Avatar
What exactly were your cold and warm control pressures, as well as the system pressure when you tested it? All these pieces of information tell different stories regarding the state of your WUR.
Also, do you have the means of measuring your AFR's - or at the very least have access to a CO% meter to check the emissions at the tailpipe? It would be helpful to know what your mixture is doing at least at idle, if not throughout the entire power band.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 03-15-2010, 01:00 PM
