930porsche
RPM dropping and shuts down after starting
1978 930 start normally and idles at 1000 RPM then a few minutes later RPM drops and the car shut down but both fuel pump still running. If when RPM drops down I accelerate to keep it up, it at first chock then it hesitate and RPM goes up. I cleaned the WUR, auxilary air valve, fuel filter. It takes longer for the RPM to drop but still the same problem. I need some help. The problem is probably staring right at me and I do not see it. What are your thoughts. Thank you.
Vacuum leak? Check all your o-rings, hoses and snug down your intake bolts.
sudo apt-get purge 930
Check the hose on the back of the AAV that is shaped like a "U". I had mine rub a large hole in it and it did that. It acted like an AAR during warm up then the idle dropped off after. Check all other hoses as well as mentioned above.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Still sounds like a WUR issue to me. Have you done a complete pressure check on the fuel system ??
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
Just one theory, anyway. Get out your gauges and check the control pressures.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
930porsche
RPM drop
I changed a new hose for the AAV. On my car, is there a fuel pressure switch or air pressure switch or regulator? It almost feels like it is loosing fuel or air pressure when RPM goes down. I cleaned up the WUR and the lf hole was very dirty with deposit so I cleaned it and use compressed air to make sure that it is debris free. The diaphragm is still in good shape. I was just wandering on the AAV, when it is cold it is 1/4 open is it normal or is it suppose to open completely? As you know there is a little slit opening weather it is open or closed. If it continues I will have to do a fuel pressure check.
Infidel
It could be that you're not getting power to the WUR, which would mean the bimetallic spring isn't warming and raising control pressure. That would be a simple check first, then have a pressure gauge on there with the ignition on to see whether the WUR raises control pressure once current is applied.
Jonathan. 87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines..... Old 540 BMW, XB12S Modified, for being a total hooligan
930porsche
RPM drop
JBL930 I will try that. Can I just turn the ignition to see if there is power on the WUR before doing fuel pressure check?
JBL's advice is right on. But I believe you need to have the engine running before you'll be able to measure any voltage at the WUR connection. Just turning on the ignition won't put any voltage there.
"I cleaned up the WUR and the lf hole was very dirty with deposit so I cleaned it and use compressed air to make sure that it is debris free."
Can't tell what you mean by this and if you put more than 16psi into the boost signal line.. it you probably blew up that diaphram and killed it. "The diaphragm is still in good shape." Which one? the S.S. fuel metering diaphram disc at the top under the fuel line connections or the boost enrichment air pressure diaphram at the bottom? With all your questions one wonders how do you know that, did you take it apart? Do you know the overall condition of the ignition, timing, and cold start timing if the hardware is still there and functioning? |
930porsche
RPM drop
Mark, the auxilary air regulator does not open all the way but 1/4 of the way. It feels like there is a spring. When I take a small skinny screwdriver and try to open it up, it does it fine but then comes right back to closing itself 3/4 of the way. Does anybody have a picture of it open while cold? If it does not open all the way, does it mean that the spring is worn out? Is there anyway to retighten the spring?
JFairman, I did take the WUR apart and noticed that the bottom diaphragm was in good shape. blowing compress air to clean it very carefully without ripping it. |
How far the TB bypass AAV slide valve opens when cold depends on the ambient temperature so you need temperature info to go with it.
930porsche
RPM drop
JFairman, in my garage it is about 70-75 degrees. How cold should it get to open up completely? Are you telling me the AAV is good? If you say that it has a lot to do with the ambient temperature then why don't we try to put it in the refrigerator and see if it opens up completely before I buy another one?
Infidel
The feed for the WUR is probably the same as the fuel pumps. Reach behind the fuel head and disconnect the cable there, with the ignition on (engine not running) the fuel pumps will then run, my bet would be that you will also get power to the WUR, not certain about that though, so check with a wiring diagram. You could run a separate source to the WUR just to see if the WUR works and sorts your problem.
Make sure you reconnect the cable to the fuel head though, it's a safety device, if you crash with the ignition on and the engine cuts, but you've ruptured a fuel line, the pumps will still fire fuel everywhere. A good test for your AAV is to remove it and put it in the fridge, leave it for a while and observe the position. Then put it in the oven on a low heat for a while, then again observe the position... Simple check like you would with a thermostat
930porsche
RPM Drop
JBL930, great idea for the AAV. I will try that.
I check the WUR and AAV heater functions and control pressures with the ignition on and pumps running because they are on the fuel pump circut.
With the engine off I've also run the battery down doing that because the 2 fuel pumps draw around 13amps and loosing battery voltage while running them completely screws up fuel pressure readings so hook up a 10 amp minimum battery charger to the battery while doing that. |
930porsche
RPM drop
JFairman, good point.
From what you've described, I would say that your AAR is working correctly, but you can always do the oven and refrigerator thing to confirm full range of movement.
Your problem lies elsewhere, probably in control pressures is my bet.
930porsche
RPM drop
Mark, I am thinking just like you. But where else can we look at? What else is controlling any sort of pressure? Switch, relay, coil?
If your car is idling at only 1000 stone cold....especially with a working AAR...then you definitely have it running too rich. Try adjusting the air correction screw in the back of the throttle body....open it up a good half to full turn and see if you get a higher idle. You may be able to tune around the car stalling, but still need to find out why. Do four things as least: (1) confirm that you have power to the WUR; (2) confirm that the WUR reacts to the power (i.e., control pressure increases as it warms up); (3) check all control presssures and the system pressure against specifications; (4) check for vacuum leaks in the intake plumbing (IC O'rings and the like). And #5...let us know what you find.
