Hesitation Problem
Guys...hope all is well.
I took my stock '87 911 turbo out yesterday after sitting for approx two months. When I got it out to the highway I noticed some hesitation around 3k rpm (when boost started to come on). After 3700 all was smooth.... Any thoughts? Thanks in advance for your help..... Last edited by 87turbo87; 03-07-2010 at 03:15 PM.. |
beancounter
Sounds like it could be fuel mixture or ignition issue. Did you put any fuel stabilizer in the tank before the 2 month lay up? Stored with the gas tank full?
I'd go through the basic tune-up checklist, check fuel pressure, check plugs, wires, cap & rotor, set ignition timing, etc...start with the basics.
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
Could be an O'ring in the IC plumbing about to go, starting to leak when boost pressure builds. That would cause a pig rich condition and associated loss of power. One of many possibilities.
Follow Jacob's thoughts, though. Check all the basics first.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
Everything they said.... Plus-chk all hoses,ignition-electrical,mechanical-Take your time--get a chair and sit behind the car,ponder,chk-list,&get to work... For me I did it...AND still couldn't figure it out...Finally pulling the plugs/looking at them,,,Gave me my answer.. Maybe some Marvel myst. oil/gas line will clear it up. Last edited by wjfk32; 03-08-2010 at 09:12 AM.. |
Same thing happened to me last year....and became worse over time. Mine was a sticky fuel head plunger..cured in 20 minutes my running Techron concentrate in the fuel....cheap option.
1988 Porsche 930 Factory Slantnose 2011 Porsche Panamera Twin Turbo 1974 Porsche 914 2.0 Phoenix Red 1965 Shelby Cobra Replica- 428FE 2007 Mercedes SL55 P30 Package |
