Just been re-reading the earlier pages of this thread. Someone posted that for the 930, the front of the A-arm is lowered by 7mm.
Would be interesting to know the ground clearance differences (front bushing mount and as well cross member) between the 911 and 930 at stock Euro ride height. Forgot to ask earlier - Is the spindle on the 930 strut at the same height as the 911 strut? Data found from another thread: '85 SC/RS front height 143+/-5mm(wheel ctr above t-bar ctr) rear height 14mm(cross tube ctr to wheel ctr) Is the SC-RS 911 or 930 chassis? |
Just found this website of an SCRS restoration, apparently a real one, and the floor mounts for the cross member appear to be 911 type.
Prodrive's First Car, aka, Porsche 911/SCRS restoration pics I seem to remember there was an article in a magazine about the SCRS and the author stated that it was 930 bodied. He probably meant the flares ![]() How is the front height 143+/-5mm(wheel ctr above t-bar ctr) achieved? |
I think some are confused here. The anti-dive added to the 930s was done by spacing the front A arm bushing system down, and by raising the rear cross member (and thus the rear A arm bushing system) up. Spacing down is easy, but to raise the cross member up (and thus the A arm bushing) you have to cut out a small section of the tub and weld in the "nut" part higher up. The factory manual shows this. The top of this "nut" actually protrudes into the trunk, as it is welded both to the lower piece of some unibody sheet metal, but penetrates and is welded to a piece above it. Makes sense, as those two 12mm bolts take up a lot of pretty heavy suspension forces.
The result of lowering and raising is to incline the axis of the A arm. The only purpose of this was to introduce anti-dive. And the spindles on the 930 A arms are, as far as I know, at the same height as those of the regular 911s. Spindles were only raised on the RS to lower the ride height. The RS came with Bilstein struts, and the spindles are fairly easy to raise on those. They are very very difficult to raise on Boge or Koni struts, as you have to section the tubing above and below the spindle on those struts. |
if you look tb axis in the A-arms you can see the inclination with the rest of the tub where the weld flanges/tub bottom are regardless of where the hubs sit or ride height etc. I dont see what the ride height or spindle places have much to do with the anti-dive as the other have stated. which RS is do you speak of 2.7RS or 3.0RS? i dont know if the 3.0RS has front anti-dive but it does have anti-squat in rears thought not as much the 930's if memory servers from frere's book. 9m's wonderful 930 resto shows the a-arm inclination in relationship to the tub/flange. on the nb cars this is near parallel. on the other pic towards the rear is notched out for the raised cross beam mounts. in fact it was Colin at 9m who informed me that the SSE/M491 cars didnt have this feature. ![]() ![]() |
Just found this tech drawing:
![]() It seems that the A-arm (911) had some pro-dive. So, the 930 A-arm were probably inclined pretty much horizontal or with a very small amount of anti-dive. Nice. |
I'd be a bit hesitant to draw that conclusion from this drawing. Yes, it looks highly accurate. But Frere and others who talked about anti-dive for turbos and the 2.8 RSR never mentioned the stock setup as having any element of "pro" dive, did they?
The diagram showing the distances from a whole bunch of chassis points to other points for use when adding a front clip or straightening out a tub and so on are all just horizontal. Is there a place where Porsche described the vertical height of these points? Maybe the Celette bench just came equipped with pegs for this or that point which were already at the proper height for the point? I'd love to see such a list. It would make it easier to come up with the XYZ coordinates to plug into a suspension program. |
It would be great if someone can post the data here. (both 911 and 930) |
AC stuff. Long gone on mine! The car in the picture has the trombone style cooler on the right side.
Garen (87 930 track rat) |
Thread Tools | |
Rate This Thread | |
